Taking a long time to fill - Washing Machines
    President:
  • 1,776 Answers
Check the solenoids at the water inlet valve. They can be checked using a multimeter or ohm meter for continuity. If either solenoid has no continuity, then the water inlet valve will need to be replaced. See the attached photo and best wishes.
Posted on Aug 02, 2009
Why does it take my washer so long to complete a cycle
If you're filling from cold then the water has to heat up if you select a hot wash. If your water preasure is very low then it could take a long time to fill every time.
Sep 30, 2014 | Kenmore Washing Machines
Why my uberhaus dual flush toilet does not flush properly
Perhaps it is taking a long time to fill the cistern, take top off and see if it's filling after flushing, if it's slow and pressure is ok it is likely to need a new diaphragm in the filling valve.
May 12, 2014 | Home
The toilet tank takes a long time to fill up
if the water keeps flowing then try replacing the flapper if it still flows then the fill tube gasket or tank to bowl gasket need to be replaced.
Mar 23, 2013 | Home
Takes a long time to fill up
A reed valve or check valve may be broken or damaged. Replace both reeds if one is cracked or broken.
Feb 14, 2012 | Coleman Powermate 60 Gallon Air Compressor
My washer doesn't stop filling with water it just keeps filling untill it overflows. Can you help?
Sorry to read about your problem, I hope this helps you out.
you have a defective water fill sensor.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Maytag Washing Machines
After commencing a programme my Hotpoint BF71 dishwasher takes in water but overfills, filling the whole of the tub nearly to door level. The waste pump starts for a short burst and then more water comes...
Check for a float switch that senses the water level. It may have two level sense of filled and overfill the latter would trigger the waste pump to avoid a flood. If the filled switch has failed, that could cause the problem. The waste pump MAY also be triggered on the basis of the filling taking too much time before the filled switch actuates... if it has failed, the time would be exceeded.
Dec 13, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
The water tank only on our Caraoma toilet only fills a drip at a time. It takes forever to fill...
There is probably some trash in the screen in the fill valve. You can try taking the valve apart and cleaning the internals, or you could just install a new fill valve. The part costs less than $10.
Aug 17, 2010 | Home
Hi i waqnt to know that in quick washing select...
The most likely reason is the amount of time needed to fill with water.. Low water pressure in your pipes can make a difference to time needed to fill..Multiply this extra time by the number of fills.. Also a blocked or faulty inlet valve can affect fill time..I hope this helps....Good luck....Nomess
May 16, 2010 | Washing Machines
Dishwasher takes ages to do the job
there is a screen in the fill valve it could be getting plugged, or you have a kink in the fill pipe , prideapplianceser@sti.net
Dec 31, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
