Question about Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit
Prestige 2 way remote 5bcr07
All of the sudden today on the above remote, there is a 'S' inside a box under the lock/unlock icon on the display. I can't find out what it is on any of my documentation.
Any thoughts?
    Scholar:
  • 55 Answers
That little "S" is the power save feature. Press the "F" and the lock buttons together to toggle the feature on and off. With the S on the battery in the transmitter will go into a power down mode when alarm is in disarmed state to save battery life.
Posted on Aug 09, 2009
My preinstalled prestige remote starter has worked twice at the dealers and i got it to work once. my question is do this combination sounds fimiliar for a chevy 1500. lock doors...lock door again, ho
If it is an add on remote starter, then you would use the factory remote to start it. If using the factory remote to start there are a couple of combinations to start it. Try lock, unlock,lock for Prestige/Pursuit models. If Directed models, try lock, lock or lock, lock, lock. If its a GM remote starter, press lock and then hold the remote starter button(circle with arrow.
Aug 03, 2012 | Prestige Appliances Vehicle Parts &...
Bought a 2002 jetta that has a prestige remote start on it. it worked fine a few months. Today nothing works..it won't start, or even trigger the start sequence, and the door lock/unlock won't...
There are two possiblities that could prove to be the fault; hood pin switch and remote start shutdown switch. If the vehicle is equipped with a hood shut down switch, you will need to make an adjustment to it for the remote starter to function. Search around the drivers side edges of the engine compartment for a push pin.If the pin is a stand alone it will be mounted near the headlight inserted into an existing hole. It may also be attached to a bracket. The remote start shutdown switch is a toggle switch located under the drivers side of the dash,usually to the left of the brake pedal, depending on the installation.
If nothing above solves the problem, you may need to reprogram the remote to the unit.
May 23, 2011 | Prestige Remote Start
I need to re-program the remotes to my alarm. It is a prestige aps255a. Just to lock and unlock all the doors. To arm and unarm is already programmed.
Huh? Pressing the lock button arms the alarm AND locks the doors. Pressing the unlock button disarms the alarm AND unlocks the doors. If this is not happening either there is an issue with the wiring from the alarm to the car or, with the vehicle's door locks.
Apr 20, 2011 | Audiovox APS255A Car 2 Prestige Platinum...
Have a prestige remote start that was installed and only worked for one week. now the remote beeps but doesn't start or lock/unlock any doors. remote says inhibited . all doors are closed as is hood and...
If this is the Prestige 997C, there is a remote starter disable feature that can be activated through the programming switch. When it is active it will display "inhibit' on the screen. To deactivate this feature, press and hold programming switch, turn key on, off, on, off, on then off. When the hood pin switch is not making contact with the hood when closed, the screen will display inhibit. When the brake shutdown wire is active the screen will display inhibit.
Feb 27, 2011 | Prestige Remote Start
Cant remember how to use the remote
To start the vehicle, press and release the Key/Trunk button two times within 2 seconds.
Jan 15, 2010 | Prestige Remote Start
Lock button is to unlock and unlock is to lock
The lock/unlock outputs from the main unit are reversed. There are two negative output wires from the unit that control the doorlocks, if you just switch them around, they will function correctly.
May 16, 2009 | Gmc Dodge Ford Reverse Back-up Sensor...
Zenith DVD Parental Lock
Try power on the player with no disk in the drive. Press "PAUSE" on the remote. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display). Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.) . Press "PAUSE" on the remote. Power the player off and then back on
Feb 17, 2008 | Zenith DVC2200 DVD Player
Gmc Dodge Ford Reverse Back-up Sensor Alarm Kit Logo
1,557 people viewed this question
Top Toyota Vehicle Parts & Accessories Experts
Randy Ohler
ashburton
Colin Stickland
Colin Stickland
Are you a Toyota Vehicle Part and Accessory Expert? Answer questions, earn points and help others
