Question about Frigidaire Refrigerators
My freezer side is working but the other side is not cooling evrythung seems to be working but my food side is not cooling
    President:
  • 744 Answers
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! and thanks for using Fixya. Mike
Posted on Aug 02, 2009
MY FRIG DOES NOT SEEM TO BE WORKING IT IS WARM
If your freezer seems to be working, then the problem is probably in the freezer section. If you remove the inner shield of the freezer and see a lot of ice around the evaporator coil then your defrost circuit is not working. If the fan is not operating, it will not blow cold air into the fresh food side. If the cooling tubes between the freezer and fresh food side are blocked or frosted up that would not allow the cold air to pass.
Since you say it is an Amana, I would suspect either the fan or the defrost circuit.
Jan 08, 2012 | Amana Refrigerators
Is not cooling
you may have defrost problem hear if compressor morking
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cooling
sounds like the fan in the freezer isn't working.
Mar 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Doesn't cool fresh food
It´s probably overloaded. Any refrigerator has a specific cooling capacity eg x Kg/24hours. you must check that capacity and charge acording to that.
Jun 30, 2008 | GE Refrigerators
Freezer works but fresh food seems warm
If you have frost on the back wall of the freezer compartment you have a defrost problem. When the freezer coil does not defrost the refrigerator does not get air for cooling.
May 22, 2008 | Frigidaire Refrigerators
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
