Question about Gateway Computers & Internet
Sata hard drive installed.. but windows setup wont detected it.
Bios detects it... but windows setup cd wont... i have a gateway ml6721 laptop
    President:
  • Gateway Master
  • 1,314 Answers
Assuming you are trying to install xp on a vista machine, you need to go into the bios and either turn off the ahci function or select IDE as the function (each manufacturer may vary slightly as to the verbage).
Posted on Aug 02, 2009
Testimonial: "sounds right"
Setup did not found any hard disk installed+toshiba s100-s1133. While trying install windows xp
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 06, 2012 | Toshiba Portege S100-S1133 Notebook
How to install windows it's showing there is no hard disk in the system pls help me
If the BIOS does not detect the hard disk, then reseat the hard disk and then check the BIOS again.
The hard disk maybe faulty, if so you need a replacement.
If the BIOS detects the hard disk and you are installing Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jul 23, 2012 | Toshiba Computers & Internet
XP installation problem - HP Cpmpaq 6720s Laptop [HDD detection error]
The hard disk is not detected because this model notebook has a SATA hard drive installed and the XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX.
Aug 12, 2011 | HP Compaq 6720s Notebook
I used winxp home service pack3 to format my hp mini laptop, when i do the setup it got an error saying " did not detect any hdd on my laptop, when i try to setup windows 7 my hdd would be...
The Windows XP disc you are using doesn't that the Hard Drive Controller Driver for that system native to the operating system. Since the system is a Mini and has no floppy drive the only option is to slipstream the HDD controller drivers into the OS CD.
http://www.fixya.com/support/r4439741-integrate_slipstream_sata_drivers_into
Jan 27, 2011 | Computers & Internet
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Hi, i am unable to install windows XP in pavilion dv6500 laptop. XP set up is not detecting the hard disk at all can you help me ?
Some copys of windows XP can not detect a SATA hard drive what you need to do is get hold of a later dvd copy of XP only the lastist dvd copys of XP are setup to detect SATA hard drives. It has to be a DVD copy as the CD copys do not detect SATA drives. Find some one with a new computer with SATA drives that has windows XP installed on it and try there copy of XP on your computer. Hopes this helps.
Jan 31, 2009 | HP Pavilion DV6500T Notebook
Installing Hitachi P7K500 Sata Hard Drive
Windows XP does not come out to support SATA hard drive, because inside do not inclued the SATA driver, that why u cannot see the harddisk during the setup. What u can do is try to install the SATA supported OS like Windows Vista or Windows 7, or maybe can "forcely" put in the SATA driver in ur Windows XP setup CD.
YBC (/\)
Dec 31, 2008 | Sprint Hitachi P300 Cellular Phone
I just replaced my hard drive and everytime i boot up it says found no operating system but when i try to install the operating system it wont let me
New hard drives don't have an O/S installed, so they just be prepped and the O/S reinstalled, along with your applications.
Does your computer "see" the new drive? If the drive was properly connected, a modern computer will automatically detect it, and you shouldn't need to do much if anything in BIOS.
There is a key sequence to get into the BIOS setup, differs from computer to computer.
Assuming the computer detects the drive, the O/S install should partition, format, and install. Some SATA machines may not install Win XP without some additional work. Do you have the CD(s)/DVD(s) that came with your computer? If so, they should have all the proper drivers (including for SATA interfaced drives).
Hopefully this will help.
Dec 23, 2008 | Gateway (M520HD80G) Hard Drive
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
203 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
