Question about Dell Computers & Internet
My dell inspiron want boot up
I went to turn i on today and t started to boot up but then it just turned off the power light was flashing green and the battary light was flashing yellow whats wrong with it
    Problem Solver:
  • 8 Answers
If your batter has gone bad (won't hold a charge) then it may not even have enough power to complete a boot up sequence. It will simply shut off from lack of power.
Plug it into an outlet and try booting it up with AC power. If that works, then most likely your battery is NG (no good).
If it acts the same way on AC power, then see if you can borrow another power cord and try it again. If that works, then the converter on your power cord has gone bad and you need a new one of those.
Posted on Aug 02, 2009
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Dell inspiron 5150 green light flashing on front won't boot up
I had the same problem, replaced the hard drive and problem went away. The hard drive developed bad boot sectors after downloading XP service pack 3. I found out later it isn't compatable with the dell I have. Hope this helps. Good luck!!
Apr 29, 2009 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 won't boot
Take out the battery. that hapened on my inspiron 3800
Nov 11, 2008 | Computers & Internet
Dell XPS M140 laptop shuts off after powering on
Most laptops that I have worked on that power off that quickly turned out to be an overheating problem. Is the cooling fan running for the brief period that you can hear the hard drive before it powers off ? If the fan is running another potential resolution might be to remove the processor and apply new thermal paste.
Nov 10, 2008 | Dell Inspiron XPS M140 Notebook
Not starting
Just to sum it up, are we talking about the Dell Inspiron 1750 or a Dell Inspiron 6000? Seeing two different things here. With the regards to the ac adapter, How "Warm"are we talking about here. 1 to 10. "1" 100 below 0 or "10" Nuclear Reactor Hot? Any adapters can get warm to the touch without overheating and frying. Was there a blackout or power outages in your area or T-Storm on the day you left. Take off the battery from the laptop. Check the battery lights. Do they flash or do they all light up when you press the button. With the laptop not working, lets hope the battery didnt fry the mainboard. Have you try to fire it up again after the adapter has a chance to cool down. By now, it should be fine, if you haven't use it.
Let me know
comier957
Aug 10, 2008 | Dell Inspiron 6000 Notebook
Dell laptop 600 inspiron
Is the laptop plugged into utility power when this happens (not running on battery power)?
If so are you able to boot into safe mode? (F8 on startup)
If not are you able to boot to a livecd based operating system? (try http://www.ubuntu.com/)
If not are you able to access the bios on this computer? (Probably del on startup)
If so are you able to underclock the cpu and try again from step 1?
May 02, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
126 people viewed this question
Alun Cox
