Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Remote will not take code
973lm remote will not take the code, followed directions but never clicks or light comes on
  • jpvip1404 May 11, 2010
    This is a 973 LM garage door and remote, everything worked fine it is about 9 years old. The Sprocket shaft that turns the chain broke I replaced. Using the wall controll everything works fine but with the remotes (2) neither one will work anymore. I have replaced the battery and tried erasing the code and it will not accept the code I hold the button on the remote then press the learn button the LED light come on but the bulb light never acknowledges it and it never clicks and about 30 seconds later the LED light goes out. But the remotes still do not work. What can I do?
Posted on Aug 03, 2009
    President:
  • 3,197 Answers
If you just bought this remote you may have the wrong one for your unit.
  • Don Maggard Aug 03, 2009
    It is important when you are programming this unit that you press the button on the remote and then press and immediately release the smart/learn button. If you hold the smart/learn button in it will erase the memory.
Is a Liftmaster 973LM remote compatable with a Sear 1.5 hp model 41A4315-7D opener?
No it is not compatable. You will need a craftsman remote or a universal remote
Sep 01, 2014 | Chamberlain 973lm Or 953cb...
IS LIFTMASTER 973LM COMPATIBLE WITH SEAR-CRAFTMAN 139.53635SRT MODEL?
Yes and No. The 973LM is Security + and the Craftsman is Billion code. You can program one to work with the other but none of your other remotes will then work.
Jul 08, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have a LiftMaster 973LM model - the remote only opens the door, but when it starts to close, it only goes down a tiny bit, then goes back up. The "Inside" remote however, you now have to press...
Check the sensors in the doorway. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have bad sensors.
Jul 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
Check your door sensors. They must be pointed at one another and the small light on each one needs to be lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
I have two 973lm remotes- how do i open them to check the battery?
usually look on the back,either a v small screw holding the batt com lid closed,or flip out type
Jul 04, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a chamberlain 953CD New will it work for a Lift-master ?
You may need a C943 as the + can make the siginal different.[Chambelain or Merlin]
Apr 03, 2010 | Chamberlain 3Button Remote Control Model...
Liftmaster 973LM. Remote opener does not work. Replaced battery - still does not work. Original owner left no manuals. Works with outside pad and inside button.
ONCE YOU REPLACE THE BATTERY YOU NEED TO REPROGAM THE REMOTE.
WATCH THE LED NEXT TO THE PROGRAM BUTTON WHILE YOU PRESS THE BUTTON ON THE REMOTE IF IT FLASHES THE REMOTE IS SENDING A SIGNAL AND SHOULD WORK.
IF IT DOESN'T FLASH THE REMOTE BATTERY MAY BE IN BACKWARDS OR THE REMOTE MAY BE BAD - IT IS NOT SENDING ANY SIGNAL AT ALL.
HOPE THIS HELPS
Jan 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Programming the remote
1. Hold on TV and POWER simultaneously (light comes on), let go
2. Press POWER then CH+ back and forth (light comes on), when TV turns off
3. press STOP, code is saved!
Oct 22, 2007 | RCA RCR412C Remote Control
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
200 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
