Question about Kenmore Dishwashers
Cleanlight blinks and wont let you do anything turn off power and still the same
  • rene1542 May 11, 2010
    the top rack doesn't seem to clean the glasses and cups a well. Just started
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Aug 02, 2009
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
LG optimus wont power on or charge
you may have over heated the battery. does the notification LED blink or anything when you attempt to turn it on?
Nov 23, 2013 | LG Optimus L9
Power light blinking on sony dvd player
Repair of a portable unit with a power supply problem inside it is likely not to be economical and parts for these units are rarely available.
No magic wand for this issue--unless was a very expensive unit replace it--
May 02, 2012 | Sony DVP-FX930 Portable DVD Player
Akai TV wont turn on right
this could be the power supply board
May 13, 2010 | Akai LCT2715 27 in. LCD Television
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
Tv wont turn on
The green light flashing indicates an error code, plasma tv's cannot be repaired at home without the right equipment and service manual, the fault could be power supply, processor or virtually anything, what technicians look for is the frequency of the blinking and the time between sets of blinks, this normally gives the tech a code that enables them to go to the right area, the only thing anyone can tell you is that the processor is probably ok, you really need to get a quote or count the blinking and the timing eg: "blink blink short pause blink), and repost the fault, then we can possibly tell you where to look...Phil
May 18, 2009 | Akai PDP4206EM Television
Xbox360 Power source
there could be a possiable problem with the brick part of the power source
Feb 13, 2009 | Microsoft Xbox 360 Console
My laptop will not turn on and the power light blinks amber
it does not display anything when you try to turn it on?
Dec 16, 2008 | Medion (40010998)
Controllers
Ahi little ben,
This is a very easy fix,
the guitars for GH run by battieries and each guitar is fitted with a power saving mode.
When the guitar isnt used for a period of time, it shuts down, and blinks[the blinking lets you know when power saving mode is on]
What you need to do is press the, usually middle, button on the guitar, its not start or select, but its usually labeled 'link'
Should work.
Good luck, PS try through the fire and flames on expert ;)
Dec 29, 2007 | Microsoft Xbox 360 Console
Dishwashers Logo
99 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
