Question about LG RU-42PZ71 42 in. EDTV-Ready Plasma Television
LG 42PZ71 this has been a great set, but it has very low hours on it and the other day I turned it on to wierd color static of some sort. when I switch to different inputs i get bands of static to the right and then again to the center. The menu and even the channel numbers no longer appear on the screen. what can this be?
  • sciacca_p Aug 03, 2009
    this is what I get when I turn on the set, no picture, no sound no on screen menu's. I have tried changing input on difference and I have also removed any signal going to the set the screen remains about the same.
    the 3 different pictures are from changing inputs and on one of them the band does move to different locations on the screen.
    It was suggested to me that this could be the PCD board, but Im not to sure.
    Please offer some constructive advise other then hire a tv repair man
    this is the link to the pictures of my problem
    http://petz-planet.com/articles/lg.html
    Novelist:
  • 183 Answers
This could be a firmware problem if the menu doesnt appear. You can get firmware updates for LG. You simply load the firmwareonto a USB stick and plug into the HDMI port then follow screen instructions..BUT DO NOT REMOVE STICK UNTIL FLASH HAS COMPLETED ELSE YOUR TV WILL BE RENDERED AS JUNK |o|
Posted on Aug 02, 2009
RU-42PZ71 displays red lines
No, you will need to call an engineer to check the display, this sounds like a fault either with the main board or very possibly (and most likely) a fault with the screen which would mean replacing the screen
Dec 18, 2009 | LG RU-42PZ71 42 in. EDTV-Ready Plasma...
Absolutely no video.
Mainboard damaged and need to be replaced, try EBAY for a general picture of prices but you will need your product code wich is located in the back of the TV next to serial number.
May 17, 2009 | LG RU-42PZ71 42 in. EDTV-Ready Plasma...
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
I just replaced the lamp and after about half hour screen goes green and blue. What is the problem?
I relaced a bulb and then my vivitek 56" started to do wierd color flickering, turns out that there was dust in the color wheel. I fixed by taking off the back and with can of air blew lightly into the color wheel area ( has tiny hole) I didn't put the nozzle through the holes. But the minute I did that a big piece of dust came out and tv is working great. Hope it helps
Feb 20, 2009 | Vivitek Televison & Video
Programming wrking fine, however i have no channel guide/listings
Call LG. They will have you go through diagnostics over the phone and ask for diagnostic data the TV has in memory.
I have done this about 10 times and my TV usually loses all it's TV guide data after I customize my channel listings (delete all the channels I don't susbscribe to). Within a day or two of calling them, my TV Guide is back to normal.
I will never buy another LG TV. Thank God I bought the extended warranty. I've had the power supply already replaced (this is also the 2nd set..replaced 1st set due to same issue), TV turns itself on at times ( in winter - low humidity/static electricity??), and loses TV Guide listings on a frequent basis (after I change the channel map).
Nov 26, 2008 | LG 42LB1DRA 42 in. LCD Television
42 in LG red dot like static on my screen still able to watch
Hi there. I don't know if you've already solved this issue, but If it's only 3 months old, contact LG Technical for Service/Repair as it will still be under warranty. It sounds like a hardware fault and would be better for you to get it done for free rather than have someone mess around with it.
Hope you have sorted it
Tim
Nov 26, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Philips projection tv have sound,no picture
wha is the make and model of your set
Nov 01, 2008 | Televison & Video
Picture distortion
and also its like a technicolor because if i have it on regular color(factory default) it will be like alot of yellow blue and white in rings around stuff thats slightly bright
and also ive maneged 2 get it to work before
i turned all the color contrast and stuff like that down 2 zero
and let it sit for a couple of hours
and then it works but i havent been able 2 get it 2 work yet for somreason
is it possible that its being caused by the power supply beingover heated?
or any other parts defected by heat or anything like that??
Jul 16, 2008 | BenQ DV3250 Television
LG Rear Projection
Look at where it's made? If it say's China, it should last from only 1 to 2 years. They don't use quality workmanship and don't offer customer support.
Sep 18, 2007 | LG RU-52SZ51D 52" Rear Projection...
LG RU-42PZ71 42 in. EDTV-Ready Plasma Television Logo
210 people viewed this question
Computer Repairing
Computer Repairing
