Question about ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard
Asus p5kpl-cm boot problem
After first boot the green light came on, the fans came on... and nothing happened! After trying again and again for 2-3 mins I powered off. After an hour I tried again, it booted, I installed WinXP professional, it rebboted without any problems I finished the setup and powered off. Now it won;t start again! Any suggestions?
    Sergeant:
  • 263 Answers
Could possibly be a fault on your hard drive the same happened to me ,I checked the hard drive on another pc and it was dead..Good luck John
Posted on Aug 02, 2009
    Scholar:
  • 89 Answers
Booting issues might be caused by power supply problems. If you plug in some other power cord, the laptop might turn on. This may be because the supply of power from the wall socket is not proper as per the needs of your laptop, or the cable that you are using with the laptop is damaged or broken from inside. You may try by changing the power cord or using another wall socket to power your PC. This can prove to be of great help most of the times.
Get more information to fix Booting Issue in ASUS .
Hope this information helps you.
Posted on Jul 18, 2011
Asus p5kpl-cm cannot power on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease
hope this helps you
Apr 09, 2012 | ASUS Computers & Internet
I updated the bios of my ASUS P5KPL-AM SE motherboard. after the update, the system restarted and it cannot boot anymore!! the CPU fan turns on but nothing is displayed on the monitor.. how do i fix this?...
your bios driver is likely to be faulty.
so download a valid driver then update your bios again.
if it doesn't work, intercept all of cables of your PC case and even power cable of your monitor.
evolve battery of bios then wait for 15 minutes then connect all of cables and try turning on your pc:
1- with battrey of bios
2- without battery of bios
it should work.
Jan 08, 2011 | ASUS P5KPL-AM SE Motherboard
Motherboard is active but nothing appears on monitor
The problem is with your memory installed try inserting other RAM on your computer or if you have two memory installed try removing the other one and see if it works.
Jul 15, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
Hi i bought a p5kpl-cm motherboard i connected everything like in the b ook but ialways have only a black screen i tried another power supply i have 2 ddr2 1g in it no graphic card Maybe the bios is setted...
well where u attach the front panel leads there is a jumper behind that with theree pins it is in the 1 2 pins change it to 2 3 and try power on after that set it back to 1 2 and then restart your BIOS settings will be refreashed. set to builtin vga again.
Jan 08, 2010 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
I put this tower in the corner for a few months, board lights up but no video (on board) when turning on, no signal message on monitor ,tried a pci video card and still nothing Worked fine prior to...
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes Pc
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Oct 12, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7 DDR2 PCI-EX16 FSB 1600(O.C.) 10 Motherboard Logo
753 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
