Question about GE GSS25SGMBS Side by Side Refrigerator
How do i remove the ice dipenser panel - GE GSS25SGMBS Side by Side Refrigerator
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
I'm not an expert, but I've recently had do so repairs to my side by side refridge. I assume you mean the control panel on the outside of the freezer door. Look underneath the panel, where the ice comes from. There is a white plastic housing. Where the white housing meets the control panel, there are 3 small holes. you can remove the control panel by using a number 1 phillips head screwdriver, or maybe even a good sized nail, and push up into the 2 outer holes. There is a release mechanism which is released when you poke the holes.
Posted on Jan 19, 2010
Ice dipenser making motor noise but not turning screw and freezer temp good but fridge side not cooling
These are two different problems. One for the ice seems to be the grooves turning the ice dispenser have been worn. For the cooling side of the refrigerator you need to replace the thermostat. Its best to call a technician if you are unsure what you are doing.
Jun 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not produce ice, no water flowing to dipenser.
Sounds like the water filter is plugged up...
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jul 11, 2010 | Whirlpool Refrigerators
Ice maker making ice but only gives out crushed ice
I had this problem and found it was caused by the flap in the ice dipenser staying open. When I manually closed the flap it corrected it. Now I have to find out how to change the flap.
Jun 13, 2010 | LG LSC27931S Side by Side Refrigerator
Ice maker doesnt produce ice
ice maker or water valve
Mar 30, 2009 | Hotpoint HSM25GFRSA
Ice cube button is lite but the only dipenses crushed ice
We have had this problem on occasion. The lever up in the ice dispencer gets jammed with frost and ice. If you remove the ice bucket/auger and let it thaw or just rinse it with water and dry it. Give it a try. -Matt
Mar 13, 2009 | Frigidaire FRS26R4A Side by Side...
Automatic ice maker will not dipense ice cubes.
This may be a circuit board problem for which there might be a recall from GE. I had the same problem and found information about it on the web site below.
http://applianceguru.com/view_topic.php?id=13243&forum_id=1
Feb 19, 2009 | GE Profile PSS26NGS Side by Side...
No Ice on GE Side by SIde -TFX25JRYF-WW
Usually there is a big metal frame-switch that controls the flow of water. It is located right above the ice tub. If your ice tub is full the ice cubes push this metal switch up so as to stop water supply. If you remove the ice tub out, chances are that you have accidentally pushed the metal switch all the way up until it clicks and stays there. In this position, the ice mold water flow is permanently stopped.
Insert the tub again in its position slowly. Before fully inserting it, pull the metal switch down inside the empty tub. With the switch down, insert the ice tub back into position.
If that does not apply for your refridgerator, look for a similar water flow switch to turn back on the water flow.
Hope this helps
Mar 07, 2008 | Refrigerators
Water/ice dipenser
Sorry, these become dirty after a period of time. Try spraying up with soap and water, clean as best you can, let dry. And then spray with a canned lubricant. Silicone type, (as opposed to WD-40 type) may work best. But OK to try either.
Feb 07, 2008 | Maytag MZD2766GES Side by Side...
GE GSS25SGMBS Side by Side Refrigerator Logo
251 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
