Question about Toshiba Televison & Video
We have a Toshiba 52 inch TV, model # TP50G50, manafactor date on it is July 1997. The picture & the sound went out all at once, do you know if it's a fuse or something more serious? It's hard to haul it anywhere being its so big and we dont own a truck. The power button light still works when you turn it on/off. Can you please help us?
    Novelist:
  • 183 Answers
It is a power supply fault. The power supply is a switched mode power supply and supplies 5 volts for the difital logic and high voltages for the high voltage parts of the tv relating to the screen display components. When the high voltage part of the circuit breaks or goes short circuit then the power supply shuts that part down leaving the low voltage rail of 5 volts..hence the standby still working. So... you need to be looking at the power supply board where the mains goes in but be aware of the mains voltages in this area if you arent experienced in electrics. The board will still hold 240v if the power supply has an open circuit load
Posted on Aug 02, 2009
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
Sony 52 inch, model number kp 53n74, stopped working
I have the same model Sony TV with a September 1999 manufacture date just did the same thing Friday! How are we suppose to find out what's wrong
Feb 22, 2010 | Sony Televison & Video
Shrinking screen
check the user manual also can be misconfigured or check the source voltages and convergence
Sep 09, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Toshiba 46in DLP No Picture, but good sound.
Hi my name is Eric,
I hope I can help you with your issue ,
Sounds like a bad lamp assembly , search for one online by model# for between $100-$200
easy to install yourself
Hope this helps, if it has solved your issue please click accept
But if you have more questions please respond and I will reply asap
Thanks
Eric
Sep 09, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Have a Toshiba TP50G50 Projection televison with no picture. Have 100 volts to power board
100 volts is too low to power the entire projection TV. Usually with rear projection TVs there are three tubes that create your picture on the screen. To power those tubes, they each require a high voltage (usually around 10,000 volts - yes ten thousand) that is produced by a high-voltage step-up transformer call a 'Tripler' - since it powers all three tubes. This device and the rest of the TV require full utility voltage (120 - 130 volts AC) to properly power the unit. Correct the voltage and try again - is the house / residence voltage like that in each room? IF so, you probably have other issues with devices you probably haven't picked up on.
http://www.tacp.toshiba.com/tacpassets-images/models/tp50g50/docs/tp50g50_om_e.pdf
Jun 23, 2009 | Toshiba 50H82 50" Rear Projection...
Is my Toshiba TV, model MW20FP1, digital?
I solved my problem by going to toshiba.com and found a list of models that ARE digital... mine is not on the list so I will get a converter box!
Dec 27, 2008 | Toshiba 27A44 27" TV
1997 Toshiba 50 inch tv
Sounds as though you have a filter capacitor bad in the power supply. I strongly suggest you have it checked and repaired soon, before it burns up a transistor or regulator. The cost may be a bit high now, but will escalate to possibly a complete power supply board. If you can repair your own set, check the main power supply filter capacitors. Good luck. I hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Feb 18, 2008 | Toshiba TP50G50 50" Rear Projection...
Televison & Video Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
