Question about Whirlpool Dryers
I have a ball of lint stick in the lint trap under the screen. i tried to get it out with a piece of wood and i dropped it and cant get it out
    President:
  • 1,273 Answers
The easiest way is to use a piece of mashing tape on a stick, with the tape wound sticky side out. Don't drop it!
--W/D--
Posted on Aug 02, 2009
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
Dropped a portable phone down the lint chute of a whirlpool cabrio dryer
Hi
That was UN-lucky. I would try using 2 thin pieces of wood to reach down into the lint trap housing and lift the phone out. This might be hard because the phone is smooth so if you have some double sided tape, apply that to the wood. If the phone is standing vertical, you may what to try using a large set of channel lock pliers to reach down. If all this fails, you'll need to disassemble the dryer. See my other solution for disassemble instructions.
Best of luck.
Dec 24, 2013 | Whirlpool Dryers
Bra stuck in lint trap housing on samsung front load dryer
You might need to remove the lint trap or the drum assembly.
Please check this video for tips
Click on Lint trap
Removing drum assembly
Jan 22, 2013 | Samsung WF337AA Front Load Washer
Lint trap not collecting lint
the lint trap is a thin gauze material and should trap plenty of lint---are you sure its there or in place properly?
Sep 23, 2012 | Estate TEDS840JQ Electric Dryer
I dropped spray bottle lid into lint trap..was removing lint trap..and lint and bottle lid fell into lint trap...how do i get it out?
Can you see it? A trick I often use is to find some very sticky tape securely attached with the sticky side out on the end of a stick, and try to touch the lid with it and hopefully it will stick to the tape. On the plus side it probably won't do any harm just to leave it if you can't get it out.
Jan 27, 2011 | Kenmore 74602 Gas Dryer
Where is the filter?
To find the filter you need to do the following steps. Find your lint trap. Lint traps in washing machines can be in the agitator (the large plastic piece in the center of the tub), at the top of the washer on the rim of the tub, or attached to the washing machine's drainage hose. Pull out the agitator tube to check for the lint trap. Peel any loose lint from the filter. Scrub away lint that doesn't peel off easily with a heavy-duty paper towel or a wet sponge. Feel your way around the top rim of the washing machine's basin. If you locate a trap, pull it straight out of the machine. Peel away loose lint and follow up with a wet sponge or heavy-duty paper towel. Check your machine's drainage hose for an attached lint trap. Remove the trap and peel the top layer of lint off. Rinse the trap in low-pressure, warm water. Reattach to the drainage hose. Check for and remove any lint or debris that may have dropped into the washing machine basin during the cleaning.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 06, 2009 | Hotpoint Aquarius WF210 Front Load Washer
How do u lift the top of the dryer so i can get in the drum of the dryer
Generally in the older dryers, the top has hinges in the back, that allow you to flip it up. To keep it from opening, there are two catches on the front base panel (about 2 inches in from each corner) and two screws under the lint trap door. First, disconnect electrical power cord, precautionary. Then remove the two screws under the lint trap door, that attach the top to the lint trap. (The next step exploits the slight flexibility of the dryer chasis.) Slide the top piece forward of the base (away from the back side) about a half inch, then lift the front edge of the top piece. (Sliding forward should allow you to clear the catches that hold the top down.) You're in....
Jul 31, 2009 | Maytag Dryers
Dryers Logo
59 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
