Computer keeps re-booting I called in last month and you all helped me fix it. But I had to wipe out my hard drive because of a hacker and did not get a chance to back it up....I get the blue screen with some tech codes the last time it was Driver I think it was the wireless driver.. I tried to re-load the same driver and it don't stop the re-boots...Please help...
  • 555 Answers
Please reboot your system then press F8 to start with a safe mode. Then uninstall the driver that causes the problem then try to check if that driver is supported with your Operating system. Or if the step above is not doing well and the same problem you encounter then i advice to reinstall your Operating system and next time do not install the driver that cause your system error.
Posted on Aug 03, 2009
Fixing Samsung np-rv510 keeps booting in safe mode
Hi
While booting press F8 key continously and there is option for last windows which worked properly, choose that and see.
Regards
Jyothish
Feb 22, 2013 | Computers & Internet
Tip
How to Completely Erase a Hard Disk Drive
Erasing a hard drive is a step that most computer users overlook. Just simply going through your data and using the delete key in Windows does not entirely delete the data. This just simply removes the shortcuts making it not visible to the user. If a person wanted, they can easily use software to obtain the data off the hard drive.
Fun Fact
A study was done and were 158 used disk drives were collected and the data retrieved. The two students found 5,000 credit card numbers, medical reports, detailed personal and corporate financial information, and several gigabytes worth of personal e-mail and pornography on those drives.
Disk Wiping Methods
There are two common methods for erasing data. These are formatting and wiping. Formatting a hard drive will not erase the data on the disk but will delete the address tables making it more difficult for average users to see the data, however, a computer specialist who is skilled can obtain some or all of the data using tools. Disk wiping is a more effective method and basically write over the data with 1's or 0's. The more times the disk is overwritten the more secure it is.
Disk Wiping Software
There are numerous free software utilities out there that will wipe your hard drive. I will recommend two programs and briefly go over them.
Eraser - Click here for download
Eraser is a advanced security tool for Windows that will completely remove data from your hard drive. It has a simple to use interface and uses multiple wiping methods such as Peter Gutmann's paper Secure Deletion of Data from Magnetic and Solid-State Memory.
You can use this program to delete files, folders, recycle bin contents and even free space on a drive. Click here for a quick start guide which will give you the basics.
-You can even use Eraser to wipe your flash drive.
Darik's Boot and Nuke - Click here for download
Darik's Boot and Nuke is basically software you boot your computer into. You can load the software into a floppy disk, CD, or USB stick if supported by your computer. Once you boot into the program, you select the wiping options and it will do the work. This is an effective program and I have used it before.
In order to boot your computer to the software you will first need to load the software on the media(usb/cd/floppy) described above then insert the media into your computer. Turn off your computer and as it is booting up you want to go into your computer BIOS. Usually, it will tell you what to press to get into BIOS during the boot up process. Once inside the BIOS you will need to change your boot order so it boots to the media device first. Once done, exit the BIOS saving your changes and the computer will boot into the media and start the data wipe software.
Tips
-If you are installing a new operating system I recommend you first wipe the hard drive using the methods described above, then formatting the drive for the new operating system. If you are giving away the hard drive or computer, I would recommend you wipe the hard drive before doing so.
I hope this article was informative. Be sure to check out my other tips and tricks by clicking on my name then clicking on "Tips" under my profile.
Regards,
G33k
Keywords
how to erase a hard drive, format hard drive, erasing hard drive, how to wipe a hard drive, how do you erase a hard drive, wiping a hard drive, erase hard drives, erase a hard drive, wipe out hard drive, wipe hard drive, how to clear hard drive
on Jun 21, 2011 | Computers & Internet
I have windows xp media center edition 2005 and i have downloaded a driver for my new monitor lg E2250 and my computer have shut down.. since that i cant load windows i cant boot in safe mode for a...
Can you reload last known good configuration? Tap F8 as the computer boots up to pull up safe mode, etc options. If that doesn't work, you're SOL. The fact you cannot even boot up safe mode pretty much means you're hosed. If you have files on that hard drive, I would recommend pulling the hard drive out and getting the data off w/ a hard drive adapter. Once all files saved, I would wipe the drive and reinstall the operating system. Sorry. Situations like that ****.
Mar 12, 2011 | Microsoft Windows XP Media Centre 2005 for...
Hi, My Gateway NV53A will not bootup. It keeps saying please insert your boot disc. Problem is that it never came with one. Can anyone help?
It sounds like your system can't read the disk sector that contains your boot up software. You will need to get a system disk from somewhere to boot up. Your hard drive may need wiped and reformatted. Try calling your tech support to see what they offer. If the computer is new I would take it back.
Feb 23, 2011 | Computers & Internet
Acer travelmate 2410 comes on does not load past the acer screen
if last known good configuration wont work (go to advance boot option before it boots to windows, then choose last known good configuration), you must reinstall your operating system using the OS cd that came with the computer. it will wipe out all your files but it will restore your computer to factory default. that is if the hard drive hasn't failed yet. if so, if OS reinstallation still doesn't work, then you have to replace the whole hard drive.
Mar 29, 2010 | Acer Aspire One PC Notebook
I have had two computer shops look at my vaoi and test everything form hard drive to software to how hot it runs etc. NOTHING. The computer works for a day and then freezes where you have to press the...
I had the same problem, and it came back twice. Last resort was to completely format hard drive and reload windows and has been running fine for 3 months now.
Sep 16, 2009 | Sony VAIO VGN-N250E/B Notebook
Wiping WD hard drive
I suggest that you use Darik's Boot and Nuke ("DBAN")application to completely Esare the Hard Drive. It is a freeware application.
Darik's Boot and Nuke ("DBAN") is a self-contained boot disk that securely wipes the hard disks of most computers. DBAN will automatically and completely delete the contents of any hard disk that it can detect, which makes it an appropriate utility for bulk or emergency data destruction.
For detail visit:
http://www.dban.org/
Good Luck!!!!!!!!!!!!!!!!
Sep 08, 2009 | Western Digital My Book Essential 500GB...
Msi hard drive 7200.9 barracuda replacement
no what You need is a sata hard drive. Check E-bay. question #2 good luck stopping hackers.
May 24, 2009 | Seagate Barracuda 7200.9 (ST3250624AS) 250...
Dell 1501 Inspiron w/Vista won't boot up -- virus?
Hi Erika,
have you tried pressing F8 when it starts booting (keep pressing it before dell bios screen fully loads)
you should get a black screen with options,
scroll up to with arrow keys>> "last known good configeration"
let me know if that works?
also have you installed any programs or hardware befor this happened?
Apr 13, 2009 | Dell Inspiron 1501 Notebook
Need to wipe my Hard drive (Acer 4720z), and don't know how to
Its called format but first u need to know what devices u have and what u wanna keep. the files u wanna keep if u dont have the external hard drive write them to cd or dvd if u have a brand comuter u can download the drivers for your computer from the manufacturers website. if u need to do the format then u most go to bios with delete or f2 key mostly in boot ordr u most but the cd/dvd drive as first. after this u save it. and reboot your computer.then insert the windows cd. when it ask from u to boot from cd press enter or any other key.
then u most use the format in setup and after that reinstall it to the same harddisk.
Jan 05, 2009 | Acer Aspire 5100 Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
