Question about Rangemaster Professional 90 SS (electric) Kitchen Range
No power to main oven or either oven light - Rangemaster Professional 90 SS (electric) Kitchen Range
    President:
  • 1,922 Answers
Check your main panel for 240volts and again at plug in on unit,unless you have some power i.e. 120volts, you need 240volts to operate oven, also check neutral on supply line into oven/lights,thats open nothing will operate
Posted on Aug 23, 2009
Oven light blew and now no power to the oven.
If you are not knowledgable in electricity, call for service.
This is an electrical short at the light, I have seen this before.
The wiring for the light has grounded to the oven. This causes the main fuse to blow. You will need to fix the short first. Then reset the main fuse/replace.
In the case of the wall oven, you may have to remove the oven to fix it properly. Depending on the model and where the short is.
Nov 25, 2013 | Zanussi ZBF360 Electric Single Oven
Gaggenau EB944-110 Pyrolytic oven stuck in some kind of mode after power outage. Oven worked perfectly but there was a mains cut. After restoring power it appears to be stuck in some kind of strange...
Yes this could be the problem. If you can't set the timer to manual mode the oven will not work. Turn the oven to on so that when power goes to it you will see the oven indicator light come on. Play with the timer buttons until the oven indicator light comes on. If it won't work you probably need a new timer.
Feb 11, 2011 | Ovens
I HAVE A HBN 43M5.OB DOUBLE OVEN AND THE MAIN OVEN WILL NOT HEAT UP AND THE RED LIGHT STAYS ON .THE GRILL WORKS ON THE MAIN OVEN AND SO DOES THE SMALL OVEN WORK.
Most likely the heater element has burnt out. This is accessible by removing the panel in the back of the oven.
*** ENSURE POWER TO OVEN IS OFF BEFORE ATTEMPTING REPAIR ***
Nov 14, 2010 | Bosch Ovens
Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
Nov 03, 2010 | Kenmore Ovens
Bottom oven is not working even though the top one is 720EF model
When you turn the bottom oven on, does the fan start to run in the oven? Do the oven lights come on? Does the main cooling fan switch on? Does the oven control knob illuminate? Does the thermostat neon illuminate?
As a guide, the power/control for the bottom oven is via the main switch on the front panel. Power then goes from the switch through the thermostat to the the oven/element/fan. The lights go direct from the switch.
I hope this helps.
Sep 17, 2010 | Stoves 720EF Electric Double Oven
Oven light won't work . No power to recepticle where do I go next?
The power come from mains go to a conector then to the back of the light switch and finnaly to light recepticle. Usualy the problem you describe from overheat of the wire which is not contacting to one of the point mention above. So you have to make a good visual inspection on one by one the points.
Pay attention once more to the recepticle since is the most posible position and is not so easy to see very clear any loose wire connection.
If you are not experiance in inspection of live wires you can make the test first with the continuity check of the multimeter without power on the oven and find where there is an open circuit on light wiring.
Jun 15, 2010 | Amana ACF4265 Electric Kitchen Range
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Rangemaster Professional 90 SS (electric) Kitchen Range Logo
138 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Mike Carew
paulcarew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
