Question about Pioneer AVIC-D1 Car Video Player
Face plate won't open
My face plate wouldn't open at first then i reset it and it worked then it stopped again the only thing i use it for is cds right now what can i do?
  • 1,889 Answers
Remove the battery from the car then spray the side of the faceplate frame with alcohol let dry completely then test
Posted on Aug 02, 2009
What does DCP stand for?
[Detachable Control Panel].. Which is your face plate.. I take your having trouble , remove all disk USB mpe attacehed remove face plate you will see a little hole you will need like a paper clip to push the button for about 2 seconds to reset the unit. after resettting attach face plate and try unit.
Feb 25, 2014 | Clarion CX609 Car CD/ MP3 Player
Won't read DVD or CDs
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 28, 2010 | Sony RDR-GX300 DVD Recorder
Will not accept either DVD or CDs why
When I hit the 'open' button the face continues to cycle
ribbon tape sounds bad. it goes from the units main board to the detachabel faces rear mounting plate , u can inspect it for cracks , most of the time theyre visibel from looking under the unit while face is open
Oct 17, 2009 | Pioneer Car Audio & Video
KRC-703 display does not work, sound does?
Check to make sure the right face came with your unit, I had an alpine once that did the same thing when I accidentally grabbed my friends face plate. Everything worked but the LCD. Check the model numbers to compare
Jan 31, 2009 | Car Audio & Video
Face plate buttons wont work
This is actually a common problem with more than just that radio. Sometimes the pins on the back of the face plate need to be cleaned. Take the face plate off, take a Q-tip and dip it lightly in some rubbing alcohol. Then use that to clean the metal pins on the back of the face plate. Make sure it is completely dry before you place the face plate back on. If this does not work, your better off replacing the whole thing.
Jan 20, 2009 | Alpine CDM-7874 CD Player
Frigidaire refrigerator making beeping sound
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
Dec 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Dual XD7600 Head Unit Problems
Sounds like the flexible connector that connects to the drop-down front panel is bad, broken pattern lead.
Aug 07, 2007 | Dual XD7600 CD Player
No Power to face plate
Hello James,You missing a Major supply to the Face,Take a Test lite and Ck to see if your getting voltage on the Memory wire Also ck Fuses ttech
Jul 20, 2007 | Kenwood KDC-2019V CD Player
Pioneer AVIC-D1 Car Video Player Logo
248 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
