Question about Acer X193W BD 19" Wide 1440x900 LCD Monitor
Acer x193x lcd monitor goes black after 3 seconds from powering up. This happens regardless of which computer it is connected to. Appears to be problem with flourescent tubes staying on, but I don't know how to fix this. I can turn the monitor off and then turn it back on and it will briefly display the output from the graphics adapter and then goes black. I have tried entering the setup menu, but it will not stay on long enough to make any adjustments. I tried hooking it up to my laptop and toggling between displays from the laptop. When it toggled to the LCD monitor it briefly displayed my laptop screen and then went blank again. One other thing, the blue power inicator led stays blue throughtout all of this. It never changes to amber, nor does it ever flash.
2 Suggested Answers
paulbtorrent
  • 34 Answers
SOURCE: ACER AL1914 LCD Monitor goes black but green light stays on
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
Monitor goes black seconds after showing desktop
Does your monitor go black because it went to sleep, does it turn off? Do you have any lights on the monitor to indicate what it is doing?
Also I would boot into safe made by rebooting the computer & tapping F8 when the bios appears. You should be prompted with several options, one of which is "Safe Mode". Choose this & report how the monitor behaves.
Jul 24, 2012 | Acer X193W LCD Monitor
Acer AL1917W blinks off in a split-second, twice
remove power to your monitor; then remove the monitor's back cover and, front cover;
when you can see the circuit board check for a buldged can capacitor or, two; replace these by unslodering them and, resoldering the new ones in place digikey.com sells the capacitors (don't forget the position of the capicitors they go in only one way
Jul 22, 2010 | Acer AL1917W LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Hit power button the screen flashes on for a second then goes black again.
I just repaired one.... will likely require that you replace 3 X 220 uf 25 volt capactiros and 2 X 1000 uf 25 volt capacitors. can't miss them the tops are swelled up. but the monitor appears to work now... not bad for 5 bucks worth of parts.
Apr 03, 2009 | Acer AL2017 20" LCD Monitor
Monitor goes to black and back on
MY LCD 22 ACER MONITOR GOES O BLACK AND I CAN'T SEE THE MENU
Nov 21, 2008 | Acer 22" X223w LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Acer X193W BD 19" Wide 1440x900 LCD Monitor Logo
306 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
