SOURCE: Freezer and Fridge side not cooling
Sounds like your Defrost heater is burned up. It is located in the back of the freezer compartment behind the lower cover. Look at the base of the condensor. Two screws hold the heater and two wire connectors. The heater is in a glass tube. Measure continuity from one end to the other, you should see a few ohms. if it is open, your heater is definitely burned. I got a good deal on a replacement heater on Ebay. I think it was $17 including shipping. The heater being bad will cause major frost buildup in the back of the freezer and stop the Ice maker from working and damage food. Be sure to thorougly dry the freezer compartment prior to putting it back in operation. If too much moisture is present, the new heater will evaporate the moisture into the Ice dispensoer motor and solenoid that swtiches from crushed to solid ice. Hope this helps. it has nothing to do with your problem, but please Check out my website www.playstationclinic.com
SOURCE: GE side by side not cooling properly/outside surface hot
please check the condenser fan motor. it is probably not running or the condenser is very dirty.
remove the rear cover and it will show you the compressor and the condenser fan.
if the fan is not running, try to rotate it manually and feel if it is sticking .
if it is, it may just need the old wd 40 lubricant.
tnx 4 using fixya,
drcool
SOURCE: lynx fridge freezer the freezer
check if there are frost at the back of the freezer wall, if there is then you have a defrost issue.
if not, check the vents if air is coming out on the fridge side. close the freezer door, press the door switch on the fridge side and feel the air. if there is no air, the evaporator fan could be shut.
if there is little air, check the vent, insert a small rigid wire, push the vent or flapper open and make the air stronger. you have a vent controll problem.
if there are ice in the vent, thaw it out and hope it won't freeze again.
SOURCE: getting very hot in the middle betweenthe fridge and freezer
The condenser fan located on the bottom near the compressor is not circulating well enough to keep the compressor at a good operating temperature causing the compressor to shut down for longer periods of time until cool enough to run again. Clean the coils good and replace condenser fan and you will be fine. The fan works as a cooler for the compressor. Imagine working in the yard on a hot day wearing a mask over your nose and mouth. Your body shuts down quicker because you have to take more rest due to the restriction of fresh air. Same applies to the compressor. Hope this helps. Rick
Testimonial: "Fan was not running at all ... big help ...thank you"
SOURCE: Divider between the fridge and freezer is hot to
This is usually normal for these units it can depen on how long the unit is running in a cooling mode.
the other thing to check is the condensor fan in the bottom back side of the fridge and make sure it is running if it is not the it needs to be replaced this will also cause alot of heat on the fromt of the unit
