Question about Garden
Have a fh541v engine on a wright stander mower,one of the cylinder seems not to be fireing. I'v got gas and spark ? I've got compresion, value's are opening, take off plug wire no change, take off other plug wire engine dies, turn on blades engine wants to stall out,will regain power but will not have enough power to move mower as it should, also has backfire seems to be coming from same cylinder, I'm at a lost Thanks for any help, Bob, Cramerba@aol.com
My guess is the guide rods are bent . check and see if the valves are closing all the way. i just experienced the same problem on my mower
Posted on Jul 01, 2010
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
I have a kawaski FH541V and is liking oil by the oil filter compartment, what should i do?
I would try tightening the filter or changing the filter the gasket could be bad on filter
Sep 19, 2013 | Kawasaki Engines NEW 17 HP KAWASAKI ENGINE...
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Suzuki gt380 running on 2 cylinders carbs clean main jet clear could it be the coil but their seems to be a good spark
HI A TWO STROKE NEEDS ONLY THREE THINGS TO RUN, WITH THE EXCEPTION OF A POINT GAP AND CORRECT IGNITION TIMEING,
1 FUEL
2 SPARK
3 MOST IMPORTANTLY IS COMPRESON,
IF YOU HAVE A SPARK THEN I WOULD NOT SUSPECT A COIL THEY EITHER WORK OR THEY DONT WORK.
IS THE PLUG GETTING WET ON THE CYLINDER THAT DOES NOT RUN? IF YES THEN ITS NOT A FUEL PROB, IF ITS NOT THEN IT COULD BE A BLOCKAGE SOMEWERE, WHEN ITS RUNING PLACE YOUR HAND OVER THE BACK OF THE CARB, YOU SHOULD THEN FEEL SOME SUCTION, DOING THIS WILL RESTRICT THE AIR FLOW AND PULL FUEL UP THROUGH THE MAIN JET, ELIMINATING A FUEL SYSTEM PROBLEM ITS HOULD THEN FIRE AS YOU HAVE FORCE CHOKED THAT CYLINDER ONLY, IF IT FIRES QUICKLY REMOVE YOUR HAND AND ALOWE AIR FLOW, IF IT DOES NOT FIRE YOU MAY HAVE A COMPESION PROBLEM, REMOVE THE SPARK PLUG, AND USE A COMPESION TESTER TO CHECK FOR COMPRESION VALUES, ALL THREE SHOULD BE SOME WHAT EVEN, IF YOU DONT HAVE A TESTER PLACE YOUR THUM OVER THE PLUG HOLE RESTRICTING IT COMPLETELY KICK OVER THE MACHINE AND THE COMPRESION SHOULD BE FELT, MAYBE EVEN BLOWING YOUR THUMB OFF THE TOP OF THE CYKINDER HEAD SURFACE, REPEAT THIS FOR ALL THREE CYLINDERS IF THERE IS A SIGNIFICANT DIFFERRENCE TO THE LESSER YOU CAN THEN SUSPECT MECHANICAL FAILURE
Oct 30, 2010 | 1977 Suzuki GT 380
Engine starts, runs rough (like cylinder missing), after a minute will run smooth a few seconds, then back to rough idle. new gas, new oil, gas filter seems clear. What else to check?
Establish which is the 'lazy' cylinder (touch the exhaust pipe header with a WET finger). There will be a marked difference in temperature. Change the plug on the 'lazy' side. If no better, check for a good spark - with engine running on the good cylinder, connect the other plug lead to a spare plug and grund the plug body. A weak/internittant spark will be readily apparant.
If there is a spark problem, replace the coil on the dud side. If not, check for equal compresion on both cylinders.
Mar 09, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
My 96 sunfire 2.2 l auto idels rough and blows out black smoke when i rev up the motor. i also hesitates on the highwy
Black smoke is from too much fuel, or a mis-firing of the spark plug. Pull all plugs to look to see if one is blackened. If so, this is your troubled cylinder. You can test each spark plug wire with a High energy spark plug tester. If that looks OK, then do a compresion test to see if the mechanical part of the engine seems good.
Oct 08, 2009 | 1996 Pontiac Sunfire
Have 2 craftsman riding mowers 42"cut one 16,50 kohler engine/the other 17hp. both have the same symptoms won't start tried plugs primed cylinders with starter fluid also gas, seems like they have no spark...
Take spark plug out ,put sparkplug wire on plug and let it lay against block. Watch to see if plug fires. If not change coil. Hope this helps.
May 18, 2009 | Garden
Garden Logo
263 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
