Question about Bosch Evolution 300 SHE33M06UC Built-in Dishwasher
Rust and scratches inside door
Have owned my machine almost 2 months. Inside the door in the spot where the top rack meets the door when shut there are some scratches and what looks like a rust line. Has anyone had this problem?
    New Friend:
  • 63 Answers
Call customer service. This should not happen; especially after only two months. Get the door (or entire unit) replaced.
Posted on Aug 02, 2009
Door doesn't shut properly to start dishwasher, have to push door to work but stops if you let go
The machine will not function if the door is not fully closed. The locking/latching mechanism for the door probably needs to be adjusted or replaced if faulty.
Also make sure there is nothing inside the dishwasher that is fouling the door (like a basket rack that is not fully in position) and is not allowing the door to fully shut. Pull the baskets out of the machine and check inside as well.
Dec 20, 2015 | Dishwashers
End of wash cycle (last 2 minutes,) F code, no spin & drain
If your getting an FdL or F11 (and possibly others) code the problem is more than likely the CCU. The CCU is a circuit board at the inside top back of the machine. The board has quality issues in that it is prone to cold solder joints at the spot where the relays and the spade connectors for external connections meet the circuit board. The repair is to remove the board and touch-up those solder joints.
Jul 06, 2010 | Whirlpool GHW9400 Front Load Washer
My kitchenaid dishwasher won't stay shut. It pops
Check that there isn't something still in the very back of the rack (top or bottom) that's sticking out and keeping the rack from sliding all the way in. Similarly, if the problem goes away when you take the racks out, the problem is with the racks. Otherwise, it's the latch: either the eye (attached to the top of the machine) is bent/broken, or the hook (inside the top of the door) is broken. Good luck.
Mar 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Dishwasher acts up
sounds like you have a bad chopper. put a cup upright on the top rack. turn the dishwasher on let it wash for about 2 minutes. open the door and see if the cup has water in it. let me know. what brand is this?
Jun 15, 2009 | Dishwashers
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Rust on the door edge of my SS maytag Ice2O refrigerator?
Your problem is no doubt a bad door gasket which is not sealing. Water vapor from room air is seeping through and condensing on the door edges. A new gasket should be available from your local refigeration supplier, but they are very difficult to replace. Read all instructions carefully before starting, and store your perishables.
Ray
Nov 16, 2008 | Continental Manufacturing Company Value...
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Wasing machine leaves rust spots on clothes.
check the basket of the machine for rust spots on the basket if thats the case the basket should have a 10 year warranty depending on the age marks are either caused from that or the dryer. if its frigidaire the dryer then the front seals probably need to be changed make sure to find out exactly which machine its coming from
Mar 18, 2007 | Kenmore 22422 Top Load Washer
Bosch Evolution 300 SHE33M06UC Built-in Dishwasher Logo
108 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
