Question about Kenmore Washing Machines
Starts to fill machine then stops and trouble code ld apears. waher will not restart when you push the start button. only fills about a inch of water. the problems are with a kenmore elite washing machine model # 11025066500 ser # cs1901174. thanks for any help given.
  • 15,935 Answers
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question !!!
Posted on Sep 11, 2010
How do I reset lg waher 1842cw it started stopped and now wont start
waher 1842cw? Have you looked at the trouble shooting measures in your manual yet? Check that first.
Feb 02, 2015 | LG WM-1832C Front Load Washer
WHirlpool wtw6600
HI,
Unplug your washer and open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass through it should not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there should be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool calypso won't drain after I removed the rug particles wrapped around the drain pump fan. Showing LD code
You will need to replace the pump. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 14, 2012 | Washing Machines
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Washer starts to fill then stops /now warsher wont wash
I too was having the same problem and I almost paid to have it repaired, which would have cost a few hundred dollars, thanfully I called the recall line after reading some of the other post on here and my machine was elgible for a upgraded on the control panel so didn' t cost anything for us. Sears told us that the F1 code is a miscommunication in the control panel, basically the machine is confused and don't know what to do so it stops and gives that code. Hope it helps!
Jun 19, 2010 | Kenmore Oasis HE 27082 Top Load Washer
F&P washing machine:GW709 doesn't cut out when filling
could b pressure switch tube is blocked or your control board with the pressure switch attached is faulty. empty water from machine, remove pressure switch hose from control board, blow thru tube to remove any blockages, refit tube. turn on cycle, select low water level, push start, after about 30sec"s push start again, that should stop it filling straight away. if the water stops push start again to continue filling. if it doesnt stop filling after restarting the cycle then it is your control module.if the water doesnt stop filling after the 30 sec stop it is the water valves. by the way what country do u live in because $120 seems to b alittle too expensive. please reply 4 more help.
Apr 29, 2010 | Fisher and Paykel Fisher & Paykel Washer
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Kenmore (Calypso) Elite Washing machine shows LD and LF!
LD means long drain and according to the manual your drain hose could be clogged or kinked.
LF means long fill. check your water hoses and the screens to make sure they are not clogged. Had that happen to me once and i had to change the hoses. several months later same thing happened and it was the motor pump part # 8054968, this you can fix yourself.
Dec 10, 2008 | Kenmore Elite 21086
Fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Oct 04, 2007 | Bosch WFE 2021 Front Load All-in-One...
Washing Machines Logo
49 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
