water will not full you hear the motor going but water doesnt come out checked and water is on if you turn knob from cold to hot and back water will flow for a little then stop
Sounds like a faulty water inlet valve solenoid. The solenoids can be tested for continuity using a multimeter or ohm meter. If either solenoid has no continuity, it is defective and the water inlet valve assembly will need to be replaced. I will attach a photo for reference. Sure hope this helped and best wishes.
Was this helpful?
Yes
No
Popular Solutions for GE WHRE5260E Top Load Washer
we have a GE model #WHRE5260E1WW that stops in mid cycle and must be started with the push start/...
(More)
we have a GE model #WHRE5260E1WW that stops in mid cycle and must be started with the push start/ stop and pause switch. This may or may not happen several times during the course of running a single load? We haven't been able to isolate a series of circumstances that would cause this to happen. However, by accident ...the washer lid slip from my hand while filling and did cause the washer to shut off, just after all the phase lights flashed on, then went out as the washer stopped, as if the vibration cause it to stop, perhaps because of loose a connection! After carefully closing the lid, I tapped on the panel face, not on the cycle control knob itself, but on the metal, on both side! Starting out with light taps with my finger tips only and gradually increasing the strength of the taps I was able to get the"cycle light" to flash and then go out! I'm not sure what that proves, but it seems to me that just by tapping at that area shouldn't cause those results. The control board is a printed circuit with only couple of wiring terminal connectors, male /female type, which all appeared to be tightly plugged together, as well as the remaining spade type single wire connections. Now unless there is a hairline crack in the printed circuit board that I didn't or couldn't see, a board component...I give up! I will say that I'm relieved to read that others have had the same or a similar sounding problems!!! problems
GM whdrr418e1ww need to remove top. I don't see where it attaches. It sounds like a hose is...
(More)
GM whdrr418e1ww need to remove top. I don't see where it attaches. It sounds like a hose is hitting the outside of the drum when it agitates.
