Question about Wahl 8550
My friend took hers apart to clean and did not pay attention how the parts came off . Hoe do I get the blades back together ? She has the 8550 model .
I have found that once you figure out how the blades fit together one scouped in small guard and one scouped out bbig blade then align holes and tighten a little on one then the other or the guard will move until both screws are tight and guard looks straight I was frustrated too but it can only wrk a certain way be patient!I
Posted on Mar 02, 2012
How do i reassemble the wahl pro series pet groomer
Posted on Oct 18, 2009
My mixer worked fine, I took it apart for a really good cleaning and now it won't work at all. Please show me how to take it apart & put it back together correctly.
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers your model. Pay attention to the Motor Brushes, making sure
they are maiking contact with the Motor after re-assembly.
Aug 15, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
I have a Bissell powerfoforce Bagless. A friend just gave me her older one, she is off to buy a newer model. I have been through every vacuum cleaner you can image, dirtdevil , kirby, etc and on and on. Sh...
There are at least 18 different models of Powerforce. There are too many parts and pieces to be able to describe what you need without seeing it. I suggest paying your local vacuum shop to put it back together. It may need a new belt, brushroll and/or filters. Do scrimp on these things if you want it to work properly.
Mar 14, 2017 | Bissell 6594 PowerForce Bagless Upright...
I would like to take my homelite vac attack apart and clean it and change oil and change spark plug and clean the gas line and other parts and put it back together. So I need a list of how you clean the...
go to www.ereplacmentparts.com for a diagram. just pay attention when taking apart. its not hard. even lable parts if you need to. an air compressor will be useful in cleaning. and brake cleaner does good on oily parts.drys quick and leaves no residue.
Jul 09, 2011 | Homelite Leaf Vac Attack
I have a stanley 99e. i took it apart ti change the blade, without paying attention, and now i can't re-assanble it properly. I can't find any instructions online.
Hi.
See here the Stanley knife disassembly. If you have a 99E there may be an additional plastic part that is not shown in the diagram. The plastic tab is located at the back of the blade.
Jun 02, 2011 | Stanley Utility Knife
I took my engine apart now putting it back together and having trouble put gears back where they should be
As with any transmission you should have payed strict attention or have the service manual with the parts schematic before scattering the parts
check this site.
Depends on the country you are in.
http://www.aprilia-rxparts.co.uk/acatalog/Online_Catalogue_17_Transmission_6_speed_19.html
Jun 01, 2010 | 2002 Aprilia RX 125
How to reassemble blades on Wahl rechargeable unit
I had the same problem and I eventually figured it out. The blade assembly has to be reassembled first then snapped back into place.
1. the bottom part has a little "nub" that the screws attach to
2. the second part is the thin piece of metal with a ridge
3. the white plastic thing, make sure the ridges are sandwiched together
4. the small blade, the blades must face each other
5. the large blade
use the 2 screws to hold the assembly together, once assembled it snaps into place on the clipper. See attached picture for how it should look once assembled.
It's STUPID that this is missing from the instruction guide that comes with the clippers.
Mar 15, 2010 | Wahl 8550
I took my Wahl clippers apart to clean ......
Okay I fixed mine. this is I what I did and it works now take the big blade and put it on a table, take the little blade and put on top of the big blade if you look closely at the big blade you can see where the little blade went, make sure you allign the blades. next take the white thing dont know what you call it bit it rotates the blades put that on the little blade, take the gold piece align with holes to the big blade and take the silver piece allign with holes and then put the screws back in. when you put it on the clipper make sure the white piece goes in the hole that rotates the blades and sould go in fine
Jun 08, 2009 | Wahl 8550
Wahl 8550 Pet Clippers Won't Work
Tried the above solutions but it all keeps falling apart. It's a wahl pro series rechargeable. There are two screws, large blade, small blade, white plastic part and a silver bracket that seems to slide on the white plastic part. What goes in first? How do I assemble it? How do blades match? Do the grooves on large blade fit into small blade? Help, I can't reassemble it. Thanks in advance! Pam
May 06, 2009 | Wahl 8550
Took unit apart to clean and need reassembly diagram please
the thick racket sit on top of the lil gold bracket
Dec 02, 2008 | Wahl 8550
How do you take a bosch coffe grinder apart?
Using a screw driver or the old butter, pry off the bottom piece.  Be careful though, getting it back together is really tricky if you don't pay attention to where all the parts go.
Feb 05, 2008 | Bosch MKM 6000 Electric Blades Grinder
Wahl 8550 Logo
760 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Ngoro
Ngoro
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
