Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Suction isn't as good as it shoule be - Dyson DC07 Bagless Upright Cyclonic Vacuum
    Scholar:
  • 44 Answers
I can help you there! Take off the whole filter unit (button near the handle) - take off the clear plastic dust bin. Wash the whole unit in water - I add a bit of washing up liquid and then keep rinsing (hose pipe outside is good) until water runs clear. Rest the right way up and leave it until completely dry. I presume you have cleaned the foam and gauze filter on the side of the machine? Finally, if you have a HEPA, then change that filter. Check the hose from the brush bar (about 3 inches long underneath the machine) isn't clogged and that should sort it.
Posted on Aug 03, 2009
Miele Silver Moon Losing Suction
if there's no blockages and filters all OK it's probably the suction fan that as worn down and not creating as much suction..
May 02, 2013 | Miele s558 Silver Moon Vacuum
My Dyson Animal isn't suctioning at full steam at all times. When I push the little gray button on the hose at the buttom of the unit on the side and pop that button and lock it in the lower position,...
Sorry to hear you're having difficulties with your DC07. From your description, it sounds as if the valve carriage mechanism may need some attention. We may be able to resolve this for you with some troubleshooting over the phone - if not, we'll be able to recommend the best course of action.
You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 18, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
Why does my filter collect so much dog hair and decreases the suction of the machine. I clean and change (alternate) filters everytime I vacumn, that isn't normal, is it? It seems like I have a seal or...
You obviously have a pet and it's good to see your machine is doing it's job. The only reason you could lose suction while collecting pet hair is due to the pet hair being a solid mass and air not been able to flow through the filters.( must be a lot of hair). Suction loss is only when the particles passing through your machine are dense therefore it will reduce suction and airflow . Very common on vacuum cleaners. Do not worry too much . Also check to see if you have Amy cracks in the seal between the drum and the vacuum cleaner itself
Jul 15, 2011 | Dyson Vacuums
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
My vaccuum lost suction
CHECK THE HOSE TO SEE IF THERE ANY OBJECTS BLOCKING AIR FLOW,ALSO CHECK THE BELT TO MAKE SURE IT ISN"T SLIPPING OR BROKEN.
Sep 16, 2010 | Kenmore 31913 Progressive Direct Drive...
No suction at the twirling brush
take a coat hanger and clean out under ...take off the brushes theres a small tunnel gets stopped up..
Sep 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
There is no suction
Either the fan is not turning to generate the suction or there is a clog
Aug 29, 2009 | Broan-NuTone CV353 Central Vacuum
Vacuum will not pick up, the dirt just lays inthe bottom of the hose and does not get sucked up,i looked for aclog but there isn,t one
Are the filters clean? Is the brush roll turning? Otherwise check the dirt inlet by the brush roll for a clog. Pull the hose off from the bottom, is there suction there? If there is, then the problem is below where the hose is pullged into. If no suction, then there is a clog in the hose, take it off, (if it comes off completely), drop something like a heavy marble down the hose and see if it comes out or not.
Jun 16, 2008 | Dirt Devil Vacuums
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dirt devil mvp not sucking
Could be bad filters, is there suction at the end of the hose. That will tell you which direction to start looking. If no suction at hose end, then filters could be the problem. If you have suction, then the problem is down lower, dirt inlet is clogged, if belt has never been changed, then I am sure it has stretch to the point that under load it doesn't turn like it should. Could even be that although the motor is running, it may be running at a slower speed, in which case it would have to be replaced.
Oct 14, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
146 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
