Question about Averatec 3200 Notebook
Upgrades for AV3270-EH1?
I know what kind of memory I need and that it will only take up to 1GB. But what are my options for CPUs and can I upgrade the Video or do I need to upgrade the whole motherboard to do that? And if so, is it possible to put a different motherboard in a laptop, or what are my options?
  • 51 Answers
You can pretty much do what u like. you just need to figure out what u r using it for pick the brands u like eg pentiun or AMD and see what they offer for your application. your only real limitation is the size of your laptop which will determine which motherboard u can use. after that just pick the hardware suited to your application
Posted on Nov 26, 2007
Upgrade intel chip to what
What do you mean? Do you want to know what CPUs are supported by the board in order to select an upgrade or what?
Jan 28, 2014 | eMachines T3656 Celeron 440 1GB DDR2 160GB...
I want to upgrade my memory on Acer Aspire 7551
why do you need more memory your machine wont work better
Jan 03, 2018 | Acer Aspire One PC Notebook
It looks like common problem: my OLD T30 can see only one 256mB memory slot. Does it make sense to install one 512 mB unit? Can T30 recognize 1gB memory? Thank you in advance
Hello
Yes, you system will support up to 1GB of ram, so, if i were you i would suggest that you buy a 1GB chip, this will give you the best performance upgrade. And, ram is so cheap at the moment, so, i think it will be the best option.
Let me know if you found this helpful.
Kind regards
Andrea
Sep 09, 2010 | IBM ThinkPad T30 2366 Notebook
Olympus c-740 reads card error when 1gb xd memory
its non supportive to 1gb card as you will have to get the device upgraded to make it support 1gb.
Mar 03, 2009 | Cameras
I have an eMachine T2240 with an Intel Celeron processor 2.20 GHz & 384 MB of RAM.  The only real complaint I have is that this machine runs slow - it is rather aged - and I tend to bump up against my...
Memory: Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot. You may purchase here.
This will give you the biggest speed increase.
CPU: I could not find specs for which cpus this motherboard supports. However, I had one of these same machines and succesffuly swapped out the celeron processor for a pentium 4 processor, 2.53 GHz. You should be safe finding a used processor on ebay that's a Pentium 4 2.2 GHz and it should work for you.
Thanks and please take a moment to rate as fixya.
Dec 12, 2008 | E-Machines T2240 PC Desktop
Reg ram upgradation
Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
FYI the memory is:
200 Pin DDR2-533 PC2-4200 SODIMM
Apr 21, 2008 | HP Presario C555nr Notebook
Upgrade motherboard?
Hello Keith,
The present Motherboard in your computer is Asus A8AE-LE. It has a lot of upgradign options.
It will support the Following CPUs.
Up to AMD Athlon64 X2 4800+
Up to AMD Athlon64 4000+
Up to AMD Sempron 3200+
Also, it has the following memory specifiations.
Memory Installed 1 GB (2 x 512)
Maximum allowed 4 GB* (4 x 1 GB) requires the replacement of the installed 512 MB DIMMs
Speed supported PC-3200 MB/sec
Type 184 pin, DDR SDRAM
DIMM slots Four
Open DIMM slots Two
And the PC has a PCI Express x16 slot you can install a high end Video Card along with a power supply upgrade.
So before you go ahead with replacing the motherboard I would recommend you to consider these options as we can cut down the cost to a greater extend and having the same iprovement on performance.
If you wish to upgrade the motherboard you can use any motherboard having ATX form factor [9.6 in X 9.6 in] in the computer. The CPUs should be selected according to the motherboard you have chosen.
Hope this helps
Pat
Mar 11, 2008 | Computers & Internet
Upgrade
Thank you for the information. Please find the CPUs supported by the Motherboard of your computer below.
Duron: 1.6 - 1.8 GHz at FSB 266 MHz
Athlon XP:
Palomi** Core: 1500+ - 2100+ at FSB 266 MHz
Thoroughbred Core: 1700+ - 2700+ at FSB 266/333 MHz
Barton Core: 2500+ - 3200+ at FSB 333 MHz
2500+ - 3200+ at FSB 400 MHz
Sempron: 3000 + and up
I see that the present processor is requires ** upgrade as it is one of the best match availble for this motherboard. However, you can upgrade the Memory to 2 GB using two 1GB
DDR 266/333/400 modules to improve the system perform performance. Also, you can consider for a video card upgrade. Your computer supports both AGP and PCI video cards.
Also, you can download the maunal for the motherboard of your computer from the link below for your referance.
http://www.elhvb.com/mboards/oem/emachines/manuals/K7MNF-64_manual.zip
Regards
Mar 07, 2008 | Computers & Internet
What kind of ram?
just look for notebook memory type ddr2, ddr2 all have the same amout of pins, you will have to remove one of the sticks of ram and replace with a 1GB or remove both and fit 2 x 1GB sticks.
seee below
http://www.ebuyer.com/store/Components/cat/Memory---Laptop
Nov 23, 2007 | Acer Aspire 5100 Notebook
Sony VGN-460 Memory & CPU Upgrade? Noisy Fan How do I replace it?
The Crucial website suggests you can put 1GB in each slot. http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-S460%20Series Sony might know which CPUs will work with this. Hopefully any Pentium-M with 533 FSB.
Sep 21, 2007 | Sony VAIO VGN-S460 Notebook
Averatec 3200 Notebook Logo
57 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
