Question about Samsung - Projection TV replacement lamp Projector Lamp
I changed the bulb in my projection tv less than a year ago and today I have no picture. The Lamp light continues to flash on and off.
    President:
  • 2,559 Answers
The lamp requires changing ever 1000 hours so it may need to be changed again.
Posted on Aug 02, 2009
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Hello, I have a Samsung HLP4663W 46 in. Rear Projection HDTV Television, and they lamp kept going out so I bought the proper lamp to replace it and it still would not show a picture. Should I pay to have...
Recheck the tv projection lamp installation?Recheck the lamp door latch,see if it is proper closed and tightly closed of the lamp door?Hear any clicking noises,when the tv projection lamp tries to ignite up.If hearing constance clicking?Mean the tv board that call the Ballast board it is also dead,this Ballast board only job are to ignite the tv projection lamp only.Ballast board must have be replaced.If the tv have a colors wheel is it dead or damage and broken require changing,u will hear major humming,motor or grinding sound noises and alot of times the tv pictures flashes multiples colors on the tv screen or the tv pictures will have a black&white flashes of a background of white light within the tv pictures background.Selling defective tvs almost impossible to sell it for a decent or a good priced or it at all.If this tv u have less than 5 years old,tv it is still have alot of it life ahead of it,tv tube picture screen panel,will last u atleast another 10 years and have to be 8 hours tv whatching every day to dies this faster or could be last to 15 years,if tv less hours of watching every day.Should get priced quotes from many tvs repair shops and get it fixed max prices about $400-$500 dollars.New tv same model and sized or difference models too will cost u like $1,200-$1,500 dollars.
Aug 06, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
I have been given a used Samsung TV without manual and have no idea how old it is or the exact size of this particular TV however, it is bigger than a 42''. I have written down the model code, serial...
The front panel LED light indication "LAMP" flashes?Change the the tv projection lamp or LED lamp first,see what happen?Than go from there?Tvs with "LAMP" LED indication light flashes,tv 1 1/2 or 2 years old use like 4 or 5 hours a day.The projection or LED lamp or bulb,inside life span is over.Require changing LED lamp or projection bulb.
Sep 10, 2010 | Samsung Televison & Video
Lamp doesnt look blown but lamp light flashing n tv wont turn on
Check the Lamp Fan if it is defective Lamp will try to light but will shut off, And the Ballast board is what turns Lamp on, For Part number o to Encompass parts distrubtion and type in your model they should list the ballast board and PN Then go to Ebay Look under Electronics type in PN, I got mine for $65.00
Lamp for $85.00
Jun 27, 2010 | Panasonic PT-45LC12 45" Rear Projection...
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Projection tv flashes green and purple tints
Find your reciept then call mitsubishi . if you purchased it less than 3 years ago mitsubishi will pay to have the expensive light engine replaced.
Oct 05, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Sony wega KF-50WE610 went dark...
If you have not changed the lamp in the 4 years you have had the tv you will need one soon if not now. is sound from tv or receiver, when the lamp dies usually no sound from tv. If you have sound from the tv try unpluging power from wall to reset and try again
May 16, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony Wega kdf-55wf655 rear projection set keeps turning on and off
If picture quality is poor, be sure you aligned the bulb in the correct manner and be sure the cover for the bulb is not loose. Also, you might want to re check you picture setting as it might have gotten reset when you pulled the plug (I hope you pulled the plug when replacing the bulb).
Heres another solution (maybe temporary) to the problem of no picture and no sound for 30 seconds. I had my tv's power saving setting on "standard" before. After I switched it to "reduced", the problem was fixed. It has been almost two weeks without the problem. I think its a good fix until the new bulb comes in the mail.
Jan 18, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
78 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
