Question about Garmin StreetPilot c530 GPS Receiver
How to replace battery of Garmin StreetPilot C530 GPS ?
This is not a job for amateurs. You will need a few special tools, and a new battery (3.7 volt / 2200 mAh).
1- Use an old credit card to gently pry off the aqua-blue bezel from the face. That's the piece of trim that fits around the screen.
2- You will see four small #0 Phillips screws. Use a #0 Phillips driver to remove these four screws. You must have a steady, firm grip, and apply a good amount of pressure, or you can strip the heads. Try turning each screw just a tiny bit at a time, until they turn easy.
3- Sit the unit on a table, with the display facing up, and the serial # facing you.
4- Grip the front part, with the display, and pull it out of the back dish, about 4 cm. You may have to jiggle it a bit, to get the steel bracket holding the satellite detector to come loose. Do not yank it further than about 4 cm or you can rip off the flat cable.
5- Fold the display down, toward you, and rest it flat on the table.
6- You will see a steel bracket holding the battery in the dish part. Remove the two #0 screws holding the battery bracket. You may have to peel it off the battery, if there is adhesive around the battery.
7- The hard part: You have to decide to solder the new leads to the speakers (if your new battery came with the special connector), or else clip the 3 wires from the old battery and splice the old leads/wires to the new battery.
Posted on Aug 30, 2009
5 Suggested Answers
  • 504 Answers
SOURCE: Garmin StreetPilot c530 Portable GPS System
You can also try pressing the wrench key at the bottom of the main screen. Then press the down arrow key. You should see a Volume icon. Press this and you should see an icon for Navigation volume. Make sure it is where you want it.
Posted on Jan 03, 2008
  • 504 Answers
SOURCE: reset my garmin streetpilot c530gps
There is no way to just "reset" the PIN. If you don't have the correct PIN, you must take the unit to the location at which the PIN was set. Your only other option is to return the unit to Garmin.
Posted on Feb 21, 2008
  • 2666 Answers
SOURCE: IS THERE A REPLACEMENT BATTERY AVAILABLE FOR THE STREETPILOT C550
There are replacement batteries available. Don't post in all caps please it is frowned upon.
Posted on Jun 02, 2009
  • 1738 Answers
SOURCE: Where should i look for the serial number for
It will be either on the bottome or on the back. It is only eight digits long.
Posted on Nov 21, 2009
Garmin does not read sd card
What size and type of SD card is being used?
The Garmin StreetPilot C530 will not support SD cards larger than 2GB or SDHC cards.
Sep 19, 2011 | Garmin StreetPilot C530 GPS Navigator GPS...
Where should i look for the serial number for Garmin StreetPilot c530 GPS
Nov 19, 2009 | Garmin StreetPilot c530 GPS Receiver
How do you change lithium ion battery in garmin streetpilot c530
The unit can be opened by removing the frame around the screen. However if you are still under warranty you will void it. The battery is not an easily replaceable one since it is soldered into the unit but if you are hany with a soldering iron it is fairly straightforward. However you have to find the correct battery which you can do with an online search.
Nov 01, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin C530 won't power up. I fully discharged battery and recharged. Unit gets warm while charging, still won't turn on. Replaced battery, charged..gets warm...still won't turn on. Are there any other...
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
Aug 26, 2009 | Garmin StreetPilot c530 GPS Receiver
Streetpilot c530 will not stay on,shuts down prior to loading maps.
battery is sogged and needs replacing or recharging on AC source
Jun 20, 2009 | Garmin StreetPilot c530 GPS Receiver
Garmin c530 does not turn on
Replace the battery 3 years is the maximum life of the battery
Jun 11, 2009 | Garmin StreetPilot c530 GPS Receiver
Jun 02, 2009 | Garmin StreetPilot c550 GPS Receiver
We would like map updates for our c530 garmin
Map updates are available for purchase either from www.garmin.com, or from a local retailer that carries Garmin GPS products.44802
Apr 30, 2008 | Garmin StreetPilot c530 GPS Receiver
Reset my garmin streetpilot c530gps
Feb 21, 2008 | Garmin StreetPilot c530 GPS Receiver
Garmin StreetPilot c530 GPS Receiver Logo
327 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
