Question about Cell Phones
When plugged into charger display says invalid
When plugged into charger display says invalid battery
    Problem Solver:
  • 6 Answers
Change your battery
Posted on Aug 02, 2009
Does not work, we tired a new battery, but no help.
Instructions
    Technical Difficulties
  1. If the phone doesn't turn on, make sure battery is charged and fully plugged into phone. Remove battery from phone and use rag to brush away dirt that may interfere with connection. Reconnect and try again. If using cigarette-lighter adapter, make sure it's properly plugged in. Make sure charger is properly plugged into outlet and into battery.
  2. When the battery doesn't charge, plug lamp or other electrical device into outlet to verify that outlet works. Borrow friend's charger to see if charger or battery is problem. Replace charger or battery if necessary.
  3. In case the phone gets wet, remove the battery from the phone and allow both to dry thoroughly. If rust or corrosion develops, wipe it off with a stiff brush. If phone still does not work, replace it.
  4. Should the display not be working, try getting it to room temperature, extremely cold or warm conditions may affect display functions.
  5. If the keys don't work, look for a display of a symbol that looks like a lock. The keypad may be locked. The display often tells you how to unlock it. If not, check owner's manual.
Jan 24, 2011 | Lands Phones
Razr V3M and get invalid charger. I am using the same charger that came with the phone though it is a new battery.
The problem sounds like your phone problem. How old are both the phoen and charger. Who is your carrier. Depending on the carrier you may be able to get the phone replace. If you have are ready purchase a new battery and it is still saying invalid charger more and likely it is the phone. Clean the battery connections with a toothbrush. Also Use can air to blow out the dirt in the charging port. Clean these areas out very well and you should be find. If not contact motorola and have them send you a replacement. If your still getting a invaild charger. You may even be able to get them to send you a charger.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Oct 31, 2010 | Motorola Mobility RAZR V3i Cellular Phone
When i plug it in to the charger it says invalid battery
ik this happened to me too well, wat i did was i kept trying to charge which the thing is that when it says invalid charger thing its becuz ur charger has some nasty things on it so wat i would do is go to ur phone company place and buy a new charger... :D
Dec 21, 2009 | Motorola Mobility RAZR V3
Invalid battery..
There is too much going on here. For starters, you should only be using Motorola accessories IE batteries, chargers, screen protectors. Now that you have done this, you have actually confused the phone, it is a "smart phone" and because of this, it is able to identify the different battery/charger. You have to send this to Motorola of for a quick fix or buy a new phone.
Oct 11, 2009 | Motorola Mobility MOTOROKR E6
Nokia 6300 dual cim china invalid charger
shud be some software prob. u need to get ur phone serviced
Sep 26, 2009 | Nokia 6300 Cellular Phone
"invalid battery" and wont switch on
my motorola fon L6 is invelid battery plise find my recuest
May 27, 2008 | Motorola Mobility L6 Cellular Phone
Invalid Battery
Try open up battery, put it back in & plug in charger again.. wait for a bit then turn phone back on. Hope this helps!
Feb 20, 2008 | Motorola Mobility RAZR V3
My L6 i motorola/ charcoal color phn
have the firmware reflash on the phone and that will take care of the issue...you are having
Feb 11, 2008 | Motorola Mobility L6 Cellular Phone
Won't turn off/invalid charger
needs operating system and new software
Jan 31, 2008 | Motorola Mobility RAZR V3
AC charger does not charge, USB connection is not recognised, but 12V car charger works!
you may have damaged battery contacts, you can fix this yourself only if you know what you are doing
Dec 09, 2007 | Motorola Mobility RAZR V3x Cellular Phone
Cell Phones Logo
321 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
