Question about GE Washing Machines
I push start and the Final Spin Cycle starts. It won't start a new load just the spin cycle over and over. Any ideas
    Problem Solver:
  • 5 Answers
Check the timer swithc
Posted on Aug 02, 2009
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Will not go into high speed final spin after rince cycle..only spins back and forth slowly and the uE indicator comes on stopping the machine. Have tried taking out a few laundry items and re-starting and...
uE is unbalanced error. When you have bulky items, wash them with a slow spin speed. Larger loads actually balance out better, so adding items might help instead of subtracting them. After the cycle completes, if you want to you can turn the power on again and (without selecting a cycle) just push the spin speed selector button and select the next highest spin speed. The load will most likely make it through the next higher speed now that it is partially spun out. You should get a 14 minute spin and pump only when you start it now.
Nov 15, 2009 | LG WM0642H Front Load
Final spin /rinse cycle won"t stop
It's usually a control board problem. sorry for the bad news :(
Jul 07, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer will not start final spin cycle
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Apr 05, 2009 | Maytag EPIC MFW9700S Front Load Washer
Final Spin
Control board needs to be checked out ,Please leave a Rating!
May 26, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer fill with water after final spin cycle
CHECK THE TIMER MODULE ,the one you pull and push to start and to stop ,that could be damaged , try different cycles , like DELICATES cycle , see what happens, hope it helps AJ
May 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
I have exactky the same problem Replaced the drum and now it will not final spin, I touched nothing else.Can't figure what could be wrong,speed board too sensitive?
It worked fine before the bearing went.
Any ideas?
Mar 05, 2008 | Washing Machines
Washing Machines Logo
15 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
