Question about Lands Phones
How can i download dorado TV15 drivers end soft
I cant use it
i have alot of problem what can i do?
Posted on Oct 07, 2009
Keeway dorado 250cc motorbike,i did change the fuse wire/modified using wire.now having problem with no power at all..cant start ..battery & fuse look working..any issue related or how to fix this?
Hi, Mustafa and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a "LOAD" test, your battery may show 12.5 volts but has little or zero amps and must be replaced.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
5. Bank angle sensor needs a reset or is faulty.
6. FOB battery low or dead.
7. Faulty ignition switch.
8. Faulty starter button.
9. Faulty kickstand or clutch pull in switch/sensor.
10. Security alarm needs a reset.
11. Starter relay, solenoid or starter circuit wiring faulty.
12. Starter armature or field coils have failed.
13. Main fuse or circuit breaker may be blown or faulty.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha Vstar 250 won start need to diagnose and fix possible fuel battery...
cranks but wont start
http://www.benelli.keeway.my/image/post/manual/dorado.pdf
https://www.aliexpress.com/store/group/Stock-Parts-2V49FMM-XV250-Keeway-Cruiser-Dorado/436449_252868059.html
Mar 25, 2017 | Keeway Motorcycles
DORADO D800 HOWTO UPGRADE AUDIO
Dorado D800 Mobile Pc Studio http://www.fileguru.com/Zend-Studio-For-Linux/download
Zend Studio is the only Integrated Development Environment (IDE) available for professional developers that encompasses all the development components necessary for the full PHP application lifecycle. Through a comprehensive set of editing, debugging, analysis, optimization and database tools, Zend Studio speeds. Free
or
http://gorillaserver.net/74192/Dorado%20d800%20pc%20suite
hope this helps
May 16, 2011 | Computers & Internet
Can't get rear brake bolts loose on 2000 cadillac el dorado
use only a socket or if you have space use a ring spanner.NEVER use open ended spanners on any nut/bolt.except to stop it turning.....
Jul 11, 2010 | 2000 Cadillac Eldorado
Where is the thermostat on a 1999 cadillac el dorado
northstar? is located on driverside wher the water pump is right infront of the radiator. it has 2 10mm bolts holding the thermostat in place. the engin coolant temp sensor is located on the driver side on the motor towards the fire wall
Feb 12, 2010 | 1999 Cadillac Eldorado
I have a Dorado D800 china mobile
You can download the PC suite and USB driver for MT6225 from Here
Oct 01, 2009 | Nokia N95 Cellular Phone
Replace window switch for 1997 el dorado
I have the same problem. I just replaced the switch ($60 from the Internet) Easy replacement, but the problem persists, Here is my next plan of attack... The PCM (vehicle computer controls the power windows for your vehicle. check the power window relay under the hood before repairing PCM. Also the cheapest way is to call local garage and ask if they have a TECH2 scanner to talk to the PCM. The Dealer will charge you about $95hr. to do this.
Jun 23, 2009 | 1997 Cadillac Eldorado
I need dorado d2000i pc drivers
I ve Dorado d2000i mobile phone, I need the driver and software of Dorado d2000i.
My name is Zubair and My email address is zab703@hotmail.com
Apr 16, 2009 | Ultra Lands Phones
MT6225 china mobile drivers
my name is Gideon, how can i download dorado d2000 drivers
Mar 13, 2009 | Nokia Consumer Headset
Lands Phones Logo
3,201 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
