Carrier thermostat Hello, My Carrier electronic thermostat is connected to a heat pump.  It was set to the COOL position during a summer thunderstorm when the AC suddenly began running no matter what the SET temperature was.  It works normally when I change it to the AUTO position.  The HEAT and EHEAT positions work normally. I tried cutting power to the unit for 2 days, after which it worked normally even on COOL, but after a short power failure it resumed the problem of running the AC continuously. I keep it on AUTO now, and it works fine for both heating and cooling.  Any ideas on making it work on the COOL setting again?
  • bluene Nov 26, 2007
    Thanks, the dr. I was afraid that was the best solution. Also thank you for the recommendation.
  • Anonymous Mar 22, 2014
    makes no difference heating or cooling
  • 447 Answers
I hate to say it but Ive had trouble with Carrier's Tstats doing similar improper things. Unfortunatly the only repair is going to be replacement of the whole tstat. I recommend Honeywell's FocusPRO or VisionPRO tstat. Ive yet to have one fail and they have a 5yr warranty if they ever do.
Posted on Nov 26, 2007
I am new to a heat pump. The thermostat has an 'auto' setting and an 'on' setting. I am confused as to which one to use for heat. Can you help me?
n most heat pump thermostats you have two control switches and the temp setting. One control switch will say "Heat", "Off", "Cool" while the other says "On" and "Auto". The three position switch is for whether you are heating or cooling. The two position switch is for the fan control. "On" will make the fan run constantly whenever the three position switch is in HEAT or COOL mode. Some people use this to circulate air at all times. MOST people use the AUTO mode, where the fan is controlled by the circuitry and runs during the times of heating and cooling only.
Oct 16, 2015 | Heating & Cooling
Heat Pump - blows heat to set temp, then off, then kicks on to blow cold
Heat pumps defrost which is the AC mode, if the heat strip isnt working during a defrost, the air will be cold, A heat pump only feels warm if the heat strips are on too! the refrigeration cycles heat output is much less sensible to our 98F skin. heat pumps that satisfy a room setpoint are working at least, all heat pumps feel drafty to most.
Oct 28, 2012 | Honeywell Programmable Thermostat Heater
Heater blowing cool air
Is it set on summer switch which is the fan running all the time blowing cold air
Feb 15, 2012 | Heating & Cooling
My robertshaw thermostat works well in summer when using my Air conditioner. I have a heat pump. but in the winter the thermostat frequently displays "ER" during cold winter nights when the unit...
what it sounds like happening is the unit is realizing it is falling behind most thermostat s have a 3 degree deadband if they fall 3 degrees or more at a time after running for so long then it will bring on the emergency heat which is located in your inside unit... when it gets really colds and you see this you need to go outside and look is the outside unit still running and is it freezing up on you...also if running check the larger of two pipes make sure the large pipe is hot to touch...based on the description you have given the thermostat is calling for emergency heat but for some reason is not bringing it on or there is a problem with the emergency heat.... hope this helps out some
repost with any additional questions...
Jan 08, 2011 | Honeywell Electronic Programmable...
A/C does not cool like it used to, unit runs
sound like your system is under sized. for every 400 sq ft of living space you should have a ton of ac or 12000 btus. also check and see if your attic fan is working. any drafty windows or doors. your supply temp should be at least 20 deg colder then your return temp. also check your filter should be changed every three months this will help with air flow.
Jun 07, 2010 | Carrier 38CKC042 Air Conditioner
Carrier thermostat reading stuck on 50 but doesn't work
If it is Carrier tstat. Some have resets other dont. Kill power to insid unit. WAit five minutes turn back on. If it has batteries take them out. But the storm may have damaged the tstat. I had a thunderstorm damage 11 tstats in one building. You can buy a tsta at Home depot that will work and they are easy to wire. Just make sure you get the coorect tstat. If the unit is straight cool electric thats the easy one. A heat pump you need a Tsta with two stage heat one stage cool. You can pick one up for about 25 to 30 dollars. Please call back for more help be glad to assist.Rusty
Jun 13, 2009 | Heating & Cooling
Heating & Cooling Logo
235 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
