Question about Plumbing
Drive shaft sticks and will not turn, have tried wd40, turns a while then sticks again. 1hp wel bilt jet pump for irrigation system.
    Champion:
  • 435 Answers
Check if the end of the drive shaft if the is broken ,it ca be burn,u will see a blue mark on it due to the heat from friction
Posted on Aug 24, 2009
My Wel-Bilt 1hp Shallow Well Pump #109231 is continually recycling (every 30 seconds). It looses about 10 pounds of pressure as soon as it reaches 40 lbs. There are no obvious leaks anywhere. The tank...
It is hard to figure out but you have what I call a water bound system. There is no air in your pressure tank. The easiest way to resolve is to drain the tank, let it fill with air, then turn on the pump, problem should be resolved for a while. There is a device that regulates the amount of air in the tank, that has failed or needs adjusting.
Nov 03, 2013 | Plumbing
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
I have a Pentair 2.0 pump that I am trying to remove from the impellar. The shaft turns allowing me to turn the pump part itself but I can not pull it loose from the rest of the housing. How exactly do I...
The impeller is threaded onto the motor shaft. On 2hp motors and above, there is usually a screw with reverse threads to help secure impeller to shaft. To remove impeller, first remove screw(reverse threads) Next, remove back cover off motor. The shaft either has a slot for a screwdriver or flats for a wrench. Hold shaft and unscrew impeller.
Aug 21, 2011 | Pentair One - Speed 1hp 115v Dynamo Pump...
I have a US!1102 AO Smith 1HP Pool Pump Motor. I was told to hold one end of the motor shaft and turn the Impeller clockwise to remove the impeller, I was told NOT to remove the nut at the center of the...
I have never taken this pump apart.
If I were in your position and I could move the impellar 1/8 turn, the next thing that I would do is carefully loosen the nut on the end of the shaft being careful that nothing else disassembles. Once this nut is loose say 2 turns, try the impellar again watching what is moving. It seems that the nut may have to be removed.
Also, I'm not sure which way the nut of the impellar rotates to remove, but you seem to have that under control since you have it moving already.
Gary
Feb 20, 2011 | A O Smith Motors A O Smith 1hp 115/230v Ur...
We have an 1hp jet pump pulling water from a 3000gal holding tank below the pump and pressure tank. when we prime the system and bleed out the air the irrigation works properly, the pump starts and stops...
depending on the motors style of start-up, if you have a centrifugal type of start winding switch, your motor may be trying to start on the run winding due to a defective contact on the centrifugal switch, if it is a capacitor type starer, you might have a defective capacitor once again the motor is trying to start on the run winding, a way to find out is to be there and listen to the motor when it tries to start and trips the barker, if the motor emits a loud humming noise you have a fault with the start-up winding control device, if the picture supplied with your post is correct the capacitor is the long cylindrical thing at the top of the motor, you can remove this and bring it to a motor shop, they can test this for you
Apr 28, 2010 | AO Smith Pool Pump Motor 1HP Square Flange...
Pump and sand filer
Sounds like the pump is not actually turning. It likely needs to be disassembled and overhauled to replace the shaft seal and bearings.
Apr 02, 2010 | Hayward SAND FILTER, PRO SERIES
When turned on the pump just has a buzzing sound does that mean that the pump is burnt out?
no its a sign of somthing stopping impeller take strainer out and check for sticks or something stopping it impeller iis in housing behind water cup may have to be removed try taking a pliers and turning shaft while pump is off this may free it
Aug 12, 2009 | Dynamo ABOVEGROUND POOL PUMP - 1HP -
WE have a EC50 system w/1HP matrix. Pump runs
Hayward Matrixs' have a one year warranty.
If it is tripping the circuit that is usually an electrical problem, and has nothing to do with the motor. Open up that back with the motor off and try to turn that shaft with a flat head, if it turns than it is an electrical problem; if it doesn't then contact Hayward directly for warranty information. Hayward is a pain to get ahold of but they are great about honoring their warranties.
The Matrixs' are fairly new and I have yet to see a shaft freeze up.
Jul 17, 2009 | Hayward EC50C Perflex Filter w/ 1 HP Pump...
Wel-bilt M/99 water pump - shaft seal - what is this thing?
Look for a local dealer in the pump reapir or electric motor repair section of the yellow pages. They likely have the bearings and the seal based on seeing your old parts.
Jun 09, 2009 | AO Smith Centurion 1081 1.5 Hp Standard...
Plumbing Logo
53 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
