SOURCE: The calculator won't convert fractions into decimals
Are you using a ti-89? If so, check your mode settings and change Exact to Approximate.
SOURCE: cant get a answer on how to program my pro-97 scanner
here is a quote from the manual; hope it helps you.
1. Press MAN, enter the bank (0-9) and channel number (00-
99) where you want to store a frequency, then press MAN
again. M and the bank and channel number appear at the
upper left corner of the display (for example: M000).
Press FUNC. Then press e or d. The bank number moves in
the direction of the arrow pressed.
Press FUNC. Then hold down e or d. The bank number
moves continuously in the assigned direction.
Press e. The channel number moves upward one by one.
Or, press d. The channel number moves downward one
by one.
2. Press PGM. M changes to P.
3. Use the number keys and ./DELAY to enter the frequency
(including the decimal point) you want to store.
If you make a mistake, press CL to delete a single digit or press
and hold CL about 2 seconds to delete all digits.
4. Press ENT to store the frequency into the channel.
If you made a mistake in Step 3, Invalid Freq. briefl y
appears and the scanner beeps when you press ENT. Start
again from Step 3.
Your scanner automatically rounds the entered frequency
to the nearest valid frequency. For example, if you enter a
frequency of 151.553, your scanner accepts it as 151.550.
SOURCE: FixYa and a scheme to get money
If you need a key for MS office that was pre-installed on your computer, but now the trial period has finished, you have 2 options
Buy a key from Microsoft.......
OR....AT YOUR OWN RISK..Uninstall the copy of office you have first.
Download a copy of Office from a torrent site. You will need a torrent client, there are loads but i use Utorrent http://www.utorrent.com/
Then look for and download a copy of office, here is a link to one, but feel free to find a different copy (It is illegal, so its up to you)
http://thepiratebay.org/torrent/5201765/MS_Office_2007_Enterprise_(Activated_And_Tested_)
This is the top of the range full version
SOURCE: fixya makes it very hard to ask a simple question!
Here are some tips:
1. Locate the casting numbers on the block. This can be either behind the distributor on the engine, or near the starter. If you have to, use the wire brush and degreaser to clean the engine and see the number easier.
2. Note the first letter in the casting number. It's a letter to designate the year of manufacture of the part.
B - 1950s
C - 1960s
D - 1970s
E - 1980s
3. Note the second number in the casting number. This is for the last digit in the year. For example, a casting number starting with B8 was manufactured in 1958.
4. Note the third letter in the casting number. This is the model design of the vehicle.
A - Generic full-size ford
C - 1966 to 1975 Remanufactured part
D - Ford Falcon
E - Ford truck
F - Foreign market or Trans Am racing engine
G - '61 to '67 Comet or '68 to '76 Montego
H - '66 to '82 heavy truck or Holman Moody high performance parts
J - Industrial Ford model
L - Lincoln
M - Mercury
O - '67 to '76 Ford Torino and all Ford Fairlane
S - Ford Thunderbird
T - Truck
U - Econoline van
V - Lincoln
W - Mercury Cougar
Y - '62 to '72 Meteor (Canada model) and '75 to '81 Bobcat
Z - Mustang
6 - Pantera
5. Note the fourth letter in the casting number. If you're looking at a complete engine, it should be an "E."
6. Note the next four digits in the casting number, generally after a hyphen or space. This is the generic part number for the engine. This number should be between 6000 and 6898 for an engine base assembly.
7. Note the last letter in the number. This is the engineering version of the part, or the design change.
Good luck.
SOURCE: The FixYa-Diagrams webpage says, "Get free
what diagram do you need? I may be able to help you.
