Dropped my unit that is a air cooler and warmer in the bay it was submerged in water will it still work
    President:
  • 2,559 Answers
If you let it dry for a few days it might
Posted on Aug 02, 2009
What kind of heat gun i need to check the temperature on my heater core hoses?
a simple inf-red temperature reader will do the trick
around $20.00 at any auto parts shop / tool shop or on e-bay
Feb 11, 2017 | Cars & Trucks
Keeps temperature but ice build up on back wall of unit. Why? How to fix? I
Water vapour in the air will continually condense and freeze on that site (presumably where the cooling panel is attached to the inner casement). Modern fridges use auto-defrost for this common problem. You could try running the cooler a little warmer, nudge up the setting one a day until ice goes. You could try rubbing vaseline on the affected area.
Jan 13, 2016 | KitchenAid KUWS246E Wine Cooler
2007 isuzu npr overheating
First off , everyone needs to know that a 2007 Isuzu npr has a EGR cooler in which hot exhaust gas is cooled via coolant , if your not familiar with this system or truck than you should not be posting. Their is a TSB on this issue , you may have a hole in your EGR cooler and exhaust pressure is getting into coolant system. Do you have any black particles in your overflow bottle ? Remove your Egr cooler , plug one coolant port and put 30psi shop air in other port with a gauge attached , pressure drops and you have a hole . you can also keep it pressurized and submerge in water and look for bubbles . Bet you that's your issue , haven't had many of these head gaskets go bad.
Oct 15, 2012 | Cars & Trucks
How do you clean the baby pro bottle warmer?
Ice container, measuring containers, and baskets: Dishwasher-safe (top rack only).
Measuring containers should be placed in a dishwasher basket. Or wash in warm water
using mild liquid soap. Rinse with clear water.
Bottle Warmer unit and removable cooler: Always turn OFF and unplug before cleaning.
Wipe surface of unit as well as inside of cooler and cooler lid, and inside of warming
chamber with a damp cloth or sponge using mild liquid soap. Wipe with clear water. Air dry.
Do not immerse in water. Do not use scouring pads, solvents, or abrasive cleaners, as
these could damage the unit.
Warming chamber (optional): Mineral deposits (usually white in color) may form on the
inner surfaces of the warming chamber and can cause damage to the unit. To remove them:
1. Unplug the unit.
2. Remove the basket, and wash separately as indicated above.
3. Pour 2 oz. vinegar into the warming chamber and let it stand for an hour or two (longer if
necessary).
4. Pour out the vinegar and rinse the chamber two or three times by pouring in, then
emptying out, 3 or 4 oz. of plain tap water. Do not immerse the Bottle Warmer in water.
Wipe dry or air dry.
Aug 21, 2010 | Avent Philips iQ Bottle Warmer without...
1997 blazer 4.3 i pulled the radiator how can pressure test to see if the motor oil cooler is bad in it
Just plug one port on the engine oil cooler, and use a hand vacuum pump to put the cooler under vacuum, see if it holds, if the vacuum leaks out you hahe a leak. In the event you do not have/ can not get a vacuum pump, you can plug one port on the cooler, and put about 15 psi of compressed air in it, submerge the entire radiator in water, with the cap and hose ports open if you see any bubbles the cooler is leaking.
Mar 31, 2010 | 1997 Chevrolet Blazer
After pugging in the water cooler, the fan starts running, all good water is cold but the fan never turns off. is this normal.
Yes except if it has a temperature control but would cut off only when it has reached the desired temperature, and water coolers are not the efficiency compared to a heat pump or air-conditioning, it only cools the air with the water running over the pads so whatever the temperature of the water is that’s the temperature the cooler will cool the air to. so in theroy it will only drop the temprature 10 to 15 degrees.
Sep 14, 2009 | Hamilton Beach Water Cooler with Storage...
My mastercool blows out hot air upstairs
The one on top probably has no water in it or the pump is not working. Look closely at the front to ascertain if water is being pumped.If not turn electric off and remove one of the side panels with a 1/4 driver. In the reservior there should be water. If not you need to turn water on to unit or adjust/replace float. Also is it's warmer than 100 degrees outside you're unit might be fine...it has limitations.
Jul 09, 2009 | Mastercool 67471 Evaporative Cooler Air...
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Remington PTAC Heater/Cooler
you may have a bad heat sequencer
Jan 11, 2009 | Heating & Cooling
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
