Question about Garden
I think the key is sheared but how does it get changed,I have done it before but it was on a briggs & stratton engine,this has a tecumshia engine.
  • 279 Answers
Remove the starter rope assembly, remove the outer casing. When the flywheel is clear, you can do one of two things to loosen it...Remove the flywheel nut and the cup, take a nut of the same size and place on the threads. Turn down only a few turns, lift the flywheel with one hand and tap the nut with a hammer in the other. Once it is loose you will see the flywheel key. Good luck...Lee
Posted on Aug 02, 2009
How do I time a 20hp briggs & stratton
with the flywheel key. they're not adjustable. if the key isn't sheared then it's in time.
Oct 15, 2014 | Briggs & Stratton Garden
Riding mower keeps back firing and will not start
you have a sheared timing key it is under thefly wheel replace says the red neck
Sep 01, 2013 | Briggs AND Stratton Intek Briggs &...
Briggs & stratton mod. 406777-0115-E1 engine backfires thru exhaust
This is a true tale sign of a valve being out of adjustment or possible burnt or sticking. Most likely its just out of adjustment. Setting them to Book Specifications of: Valve Clearance (cold) IN and EX .005" (0.13 mm) should take care of the problem. Since you said that it runs fine rules out the possibility of a sheared flywheel key, though I have seen one run with it slightly sheared. Thanks; George
Apr 22, 2013 | Briggs & Stratton Garden
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
Briggs & stratton 5hp motor will not start
Check the flywheel key, it may have sheared. If the key shears it will throw timing way off. This would cause a backfire or "pop". Start there and let me know, Daniel
Oct 22, 2012 | Garden
Briggs and stratton engine on my lawn mower won't start.
Remove the blade and check the keyway. If the key way has the shear pin still in it it may have been bent and not sheared off. That will cause it to be off timing. I would imagine the valves got bent from the sudden stop of the engine as well
May 16, 2010 | Briggs & Stratton Briggs Stratton Intek V...
How do you time a 20 horsepower intex engine
i believe the ignition timing is not adjustable , if you think you might have a timing issue you need to chech if flywheel keyway is twisted or sheared
Mar 04, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
