Question about Hitachi CP-X440 Multimedia Projector
Hitachi CP-X440 Projector
Hi because of the distance in order to get the best size of screen could i fit an extra lens to be able to zoom a bit closser . thanks
Re: Hitachi CP-X440 Projector - Hitachi CP-X440 Multimedia Projector Multimedia Projectors
I need to reset the timmer on the fillter
Posted on May 12, 2008
0 characters
3 Points
Driver download
Dell :Fn + F8
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
Oct 16, 2013 | Hitachi CP-S318 Multimedia Projector
I cannot adjust the focus ,zoom ,or tilt on my Hitachi CP-X1250 projector
try adjusting it from the remote and from the buttons on top. if neither work there is a connector from the main board to the lens contacts you might be able to see it and adjust it having taken out the lens (bayonet with lock button. if all still fails I have a few spare main boards from lcd dead projectors, reasonable to replace. email me
Dec 22, 2012 | Hitachi CP-X260 LCD Projector
Hi, our Hitachi CP-S225 will not work with our new laptop EliteBook 8440p. Our IT support has said it is because we need a driver. Can you please help?
What did they say the driver was needed for. Aren't you just using the vga output of the PC to feed the video signal to the projector. No driver is needed for this
Jan 25, 2011 | Hitachi CP-S225 Multimedia Projector
I have a Hitachi LCD projector model No. CP-RX70. When I connect with my laptop (Compaque) and start both then only starting window XP message appears through projector and laptop works normally but again...
The setup is not correct. Check the requirements of the projector, (size, refresh rates etc.) and set the laptop up accordingly.
You will se the XP Screen because the laptop hasn't loaded any drivers yet and the screen is low resolution.
Hope that helps.
Dec 06, 2010 | Hitachi Performa CP-RS55 Multimedia...
I moved to a new house and the image does not fill the whole screen like before i already ck the zoom on the lens
I'm sorry,but the product cannot project the required size from the current distance from the screen,I tend to use a short throw lens projector for this.
May 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
Hitachi projector cp-s318 and the pictures give off a red tint.
Make sure the Computer Input is set to VGA, Computer, or RGB (depending on which projector model you have). Go through the menu settings of your projector.
Hope this helps
Apr 01, 2010 | Hitachi CP-S318 Multimedia Projector
Have changed the bulb because of yellow blob on the picture and it has made no difference
the yellow blob is from a fried polarizer on the blue lcd panel due to excessive dust and heat. you'll have to replace it, but hitachi doesn't sell individual optical engine parts, so you may have to replace the whole optical engine.
Jan 18, 2010 | Hitachi CP-X440 LCD Projector
Hitachi cp-s240 blue tint cloud problem
This might sound like a worn spot in the (blue) lens from heat, or a bad color driver on the mother board. It could possibly be dirt or condensation behine the lens(s)
Jun 19, 2009 | Hitachi CP-S240 Multimedia Projector
Hitachi cp x880
well lens assembly has to be repaired. try
Jul 21, 2008 | InFocus LP70+ Multimedia Projector
Size of Projection
Hi Jez
Distance is definitelly your problem here - the lens can only reduce so much. You will have to move the unit.
Nov 30, 2007 | Optoma H30 Multimedia Projector
Hitachi CP-X440 Multimedia Projector Logo
116 people viewed this question
Top Hitachi Multimedia Projectors Experts
Electro Med Services...
Are you a Hitachi Multimedia Projector Expert? Answer questions, earn points and help others
