Question about HP Computers & Internet
HP W1907 Won't stay lit
I have an HP w1907 desktop monitor. I will turn on and stay lit for 2 seconds, then it gets very very dark. Auto adjust didn't fix it, is there anything that can be don?
  • m33k3r Aug 02, 2009
    Tried it with another monitor and it worked fine. It must be a monitor problem....Any suggestions?
  • 55 Answers
You may try to rule out the monitor problem by using another monitor. If it does it with another monitor than it may be your video card. Also make sure you check your cables to ensure they are connected properly.
Posted on Aug 02, 2009
Auto adjustment in progress keeps popping up
Try turning down the brightness on the monitor, sometimes this will fix the issue, if not the problem is in the inverter board and needs a professional to assess it further.
Mar 10, 2012 | HP w1907 LCD Monitor
Hp w1907 keeps auto adjusting every 5 - 20 seconds
happened once to me, (I have this exact monitor), heres what i did that fixed it:
Unplug all cables from monitor, leave it unplugged for a few mins.
Replug cables in starting with first the power then let it come up,
then plug in the VGA cables, and see if that fixes it. If not use the buttons on the front to switch input channels and maybe you can get it that way.
Feb 13, 2011 | HP w1907 LCD Monitor
Hp W1907 SHUTS OFF AFETR 2 MIN
sir u should go to control panel then change the monitor timing i think u have adjusted it 2 minutes...........expand it ....... bye bye if any problem occurs mail me at vicky.akon11@gmail.com
Mar 23, 2010 | HP w1907 LCD Monitor
My hp w1907 19' monitor goes black light stays green
it sounds as if you may have a backlight problem..i have two of them that the wire going to the backlight had burnt off at the bulb..I had to take the lcd screen apart to solder the wire back on the blub.. be carefull the lcd screen and bulb are frigile... ther is 4 lights two on the top and two on the bottom..good luck
Nov 10, 2009 | HP w1907 LCD Monitor
Auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Jun 09, 2009 | HP w1907 LCD Monitor
My hp w1907 monitor is constantly auto adjusting every 1 or 2 seconds. Make it stop.
Good morning! Auto adjustment occurs when resolution or refresh rate of the display changes. Check your display setings in OS. Set them properly according to product operations manual. Update your display adapters driver. Also check your VGA card or motherboard display port & try using a different cable. try pluging the monitor to a different computer or plug in a different monitor with your motherboard or VGA cards display port. best regards
May 03, 2009 | HP w1907 LCD Monitor
Monitor won't stay on.
hi there your problem .your monuter backlights gone so u need to new backlight
Feb 25, 2009 | HP w1907 LCD Monitor
Hp w1907 monitor on start up shows the wrong resolution
Have you tried adjusting the resolution to the prefered resolution, than shutting it down properly.
(Not pressing off button, or if laptop closing screen,
Contact me if this does not work,
Regards,
Asitomani
Feb 10, 2009 | HP w1907 LCD Monitor
Computers & Internet Logo
193 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
