Question about Panasonic DMR-E55 DVD Recorder
The machine is stuck on self check mode.Any help please
  • 158 Answers
REPLACE THE PSU REGULATOR- STRG6353A
Posted on Aug 03, 2009
Do we leave the racks in the oven while cleaning it ?
Hi.
I assume you are referring to the "self-clean" function of your oven, in which case, the answer is no. All racks and the broiling pan, etc should be removed from the oven before initiating self-clean mode.
I can't give any specific instructions for the self-clean mode on your oven as you have not specified a brand or model number. If you need any further assistance, please post back with these details.
Please note: The high temperatures generated during "self-clean" have been known to cause the door locking mechanisms on many ovens to become stuck in the closed position. This often requires a service call to rectify the problem. If you are planning to use the self-clean before cooking your Christmas meal tomorrow, please bear this in mind. There is little chance of getting a service call between now and then.
Hope this helps.
Happy holidays!
BElectric.
Dec 24, 2010 | Ovens
Our xerox workcentre 4150 is stuck in a self test mode. We have turned off the machine and unplugged it several times, and it keeps going back to the message Please wait....Machine self test in progress....
You will either have to take off the back cover and remove the memory battery. One of those round lithium batteries and reinstall it or go to xerox.com, download the newest level of firmware and load it to the machine.
You may also want to try turning the machine off. unplugging the hard drive and see if it works like that.If it works without the hard drive replace it. If all those steps do not work replace the main board.
Aug 13, 2010 | Xerox WorkCentre 4150 Black and White...
Have the machine in self test mode and dont know what each button
Just read your machine user manual.you will find detail info.about all the button.
NOTE: Do not skip ''self test". because during self test mode machine check it self & make sure that it is working properly.
Jun 15, 2010 | Robinair Cool Tech 34700Z Recovery,...
My machine goes into self checking mode and gets stuck.
If it's going into self-checking then either there is a problem with the drawer deck mechanism not being able to communicate with the logic board, hence the reason it stays in the self check. Contact your local Panasonis dealer to arrange a service engineer to perform a software update on the recorder as your current software could either be an older version or has been corrupted & needs to be updated.
Sep 05, 2009 | Panasonic DMR-E55 DVD Recorder
Dyson cro1 stuck in self clean mode??any ideas
hiya did you have any luck with your self clean problem? I only ask cus i have the same problem kind regards Dave
Apr 05, 2009 | Dyson Memory CRO1 Front Load Washer
Starts a self check then power goes off
Not sure if this will help. My machine was stuck with a "Please Wait" message. Searched internet, many folks with problem. The fixes all pointed to 2 capacitors being blown. My brother was able to easily solder 2 new ones in and the machine worked perfectly. If you Google the name and model with Please Wait after it, you will see some of the conversations and remedies. Your machine may be heading toward this problem.
Also, beware of storing too much on your hard drive! My machine was working great after the above repair, but I believe I had too much stored on mine and I got a U99 Error Code. Service Center said it can not be repaired and THEY DO NOT MAKE THESE ANYMORE. There are DV machines with a hard drive so you can watch shows, but not to record show/movies. I make DVDs of my son's high school games. Can edit and transfer many games at once with this machine... not with any others!
Do not let this one die on you. It is priceless.
Feb 02, 2009 | Panasonic DMR-E85H DVD Recorder
Stuck in self check mode
Manually pull down the front shield, then somewhat forcefully pull down the inner shield and maybe two little white pins so the tray is exposed with nothing blocking it. Have someone plug the machine in while you are holding everything out of the way and the tray should start to open. Pull your fingers out quickly so you don't block the tray from sliding out.
Mar 16, 2008 | Panasonic DMR-ES10 DVD Recorder
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
DVD recorder DMR-E55
You can try a factory reset (reboot).Here are the steps..
The following will set your recorder to the Factory defaults.
(Will not format HD on DMRE80).
With power off (stand-by mode/CLOCK DISPLAY SHOWING):
1)Press and hold [skip reverse] [Time Slip] [Eject] buttons for about 10 sec
2)Display will show 'L1 TEST'
3)Now power off DURING TEST
4)Clock should be fashing 12:00
5)Turn power on and language menu will be displayed on TV
Use for
DMRE50
DMRE55
DMRE85
For the DMRE75V press both [dub] buttons and [eject].
Hope this helps.
Nov 20, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
387 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
