Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
I need to locate the receivers frequency to change it, since i have fans and they interfere.
    President:
  • 2,976 Answers
There are tiny switches in the remote and the bottom of the fan where the wires are.
Posted on Aug 02, 2009
How to change frequency interference range on AKG rs 40 wireless microphone?
Go on line and search for operators manual. You may have an older unit with frequencies that were given away from the AV world to the internet world and this may ultimately be the cause of interference.
Do a search of legal frequencies for microphones
Jul 12, 2016 | AKG Wms450 Presenter Wireless Microphones
We have frequency interference
Change the frequency in your receiver & transmitter.
Oct 12, 2013 | Minka Aire Ceiling Fan
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I cannot connect my Wii to the internet. Is there a part that I need to connect, or is there something else that I need to do in order to get the wireless connection working?
Here is a step by step instruction on how to connect your Nintendo Wii to the internet. Please note that connecting the Wii to the internet does require a wireless connection, or wireless router for a signal.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
copy and past this into your internet browser.. if you should receive an error for any reason, here directions and a link to solve it.
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Sep 03, 2011 | Nintendo Wii Console
Aug 23, 2011 | Nintendo Wii Console
I bought 2 Minka fans and they are located within 30 ft of each other. The remotes operate both fans at the same time. The manual explains how to reprogram the transmitters but when I reprogram one how do...
The ones I've seen previously had DIP Switches in the Fan Receiver that had to be set the same as the remote.
If this is no longer the case then you'll need to isolate the supply to the fan that you want to keep as the original frequency.
If they're both wired on the same supply with the same wall switch then the only way will be to disconnect the supply at the fan and make the ends safe while you change the frequency on the other.
Jul 03, 2011 | Minka -Aire Brushed Nickel Remote Control...
Have to be right next to the door for the openers to work. Changed batteries with no change.???
Sounds like a faulty receiver or interference on the same radio frequency, try turning off any other wireless devices nearby to isolate the possible source of interference. If this does not work it might be worth fitting a universal remote control on a different radio frequency universal garage remote control
Dec 23, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
Light comes on without pressing remote button
You either have a faulty remote/reciever, or you are getting interference from some other electrical device. before you change the remote/reciever try changing the frequency on the remote and the receiver. You will have a set of dip switches or jumper blocks on posts in the battery compartment of your remote and on your receiver inside the decorative canopy cover against the ceiling (sometimes the receiver is built into the motor housing and can be seen from above the motor without opening an access) just make sure the code you use is the same on the remote and the receiver
Sep 07, 2009 | Hunter 52" Ceiling Fan With Light And...
I just had a stereo put in with a remote and now my fan won't come on. I suspect the remote control setup for the stereo has done something to the fan????
The RF (radio frequency) can interfere as you suspect. Most fans allow you to change the frequency that it's programmed to. Check your mnual to see if you can change yours.
Jul 13, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter fan model 23272 with remote control
Sometimes fan remotes can get interference from several rf sources (maybe another fan remote or garage door opener, etc). You can try to change the DIP switches in the remote and the reciever to a different frequency. The switches in the remote are probably in the battery compartment, and on the reciever which is located in the ceiling canopy (most likely), or in the round box where the light kit attaches.
Jan 07, 2009 | Electrical Supplies
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
157 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
