SOURCE: Zenith ZHX-313 DVD/Video Player
I also have this model and it took me a long time to find the solution. It turns out this model is actually an LG.
If you use the instructions for an lg-6000, it worked for me.
Here is a thread I found on another site:
I found a website (http://lgregionfree.tripod.com/) that has a different CD image for LG 6000 series players. I tried that and it works, my player is now set to region 0 and has played region 1, 2 and 4 discs.
Here is the process:
1) Download http://lgregionfree.tripod.com/6000.zip
2) Extract the ZIP file, which contains a Readme file and a directory named RMTM0000
3) Using a CD burning program, burn the RMTM0000 directory to a CDR, making sure to use the ISO9660 file system instead of the default Joliet. Finalize the disc.
3) Turn on the player and insert the disc. The Region Test Menu screen should appear.
4) On the remote, press your desired region (or 0 for regionfree), then press Enter then Pause.
5) Eject the CDR and turn the player off.
6) Turn the player back on and enjoy.
NOTES:
a) I did not need to wait a minute between region selection and pause.
b) On some players this hack causes the buttons on the player itself (not the remote) to stop working. I can confirm that on the XBV443 the player buttons continue to work.
SOURCE: Re: Zenith dvd/vcr Combi Receiver ZHX-313
alanomarie, I had the same basic problem, was able to remedy it by selecting sound mode on my remote and pressing it till unit displayed 'prologic'. Hope this is of help.
kino536
SOURCE: how to setup receiver stations on a Zenith model
choose the station then push the memory button
SOURCE: DVD drawer will not open
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
SOURCE: I need a manual for a Zenith ZHX-313
There's a full manual at:
http://safemanuals.com/user-guide-instructions-owner-manual/LG/ZHX-313-_E
It's in .pdf format so you can even download to your computer for future use.
