Question about Philips WACS700 Shelf System
Connect my center wireless via my route to my pc, but i have no
I have a wac700 philips wireless music center and i want to connect to my pc wireless which runs on vista but the cd i had didn't work with vista
can you help
thanks
paul
ps
once connected can i put all the music tracks that i have loaded on my music center to go into my itunes and vica versa
If you open the CD contents in a folder and run the Setup in XP compatibility mode, and the software should work. <div><br /></div> <div>Good luck from there! I still can't get my PC to recognize the music center.</div>
Posted on Aug 17, 2010
I am having trouble finding a module for my Philips wAC700 and for someone to repair this. I was wondering if anyone knows where I could get another system instead.
Contact Philips they should be able to help find a service center to repair the unit. Or tell you where to find a replacement.
Nov 19, 2014 | Philips Audio Players & Recorders
Phillips wac700 says booting up has not been used for a while
Hello
Just unplug the device from AC mains socket and replug it after 3 minutes and see whether it helps you. If not, a firware upgrade will be necessary. The supplied PC installer CD contains Media Manager [DMM] software. it will help you to upgrade for WAC700 center. For details see DMMs' help file. Refer to the manual CONNECT YOUR PC to learn how to install the software. OK.
Jan 16, 2012 | Philips WACS700 Shelf System
How do you connect an ipod or mp3 to the waC700 wireless music centre?
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
Feb 20, 2011 | Audio Players & Recorders
Streamiun Wac700 CENTER says can't connect to center...help!
put units side by side and switch them both off. Plug in main unit, and using menu resort factory settings, then when it reboots, select language, and leave it there. Then connect the smaller unit and do the same thing (restore settings), they should then find each other.
Apr 27, 2009 | Philips WACS700 Shelf System
Wacs700 connection to my pc via wireless
use http://www.lucia-mathias.com/wacs/, it will find music center as long as security settings for wireless are correct, if never connected to a pc use the original pilips disc to set up first
Aug 13, 2008 | Philips WACS700 Shelf System
Saving music on hard drive
After the MP3 songs are transferred from the PC to the Music Center via DMM, do not disconnect the power cord. The Center is updating its internal database to mark the changes of music library. Wait for around 20 minutes to let the Center update the database completely. When the internal updating is complete, you will be allowed to turn the Center into ECO Standby mode.
Apr 06, 2008 | Philips WACS700 Shelf System
WAC700 Wireless music center
This can be caused by either corrupt firmware, or bad connection between the front panel and main unit.
The firmware can be restored as follows:
Unpluck the unit from the mains.
Press and hold [STOP] & [SOURCE]
Plug unit into mains.
Continue to hold the two buttons until the recovery message appears on screen.
If the progress bar doesn't move at all within 5 minutes, then this is not the problem.
______________________________________________________
This problem can also be caused by the ribbon cable connection between the front panel and the main unit. Sometimes the problem can be cured by disconnecting both ends of the cable.
The firmware should still be ok in this case.
There are multiple processors in the WACS700 unit, and the problem occurs when they can't talk to each other.
An authorised service agent should be able to sort the problem with a replacement cable.
Mar 15, 2008 | Philips WACS700 Shelf System
WACS700/05 Wireless Music Centre will not Boot up
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
Aug 20, 2007 | Philips WACS700 Shelf System
Philips WACS700 Shelf System Logo
433 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
