Question about Kenmore Washing Machines
Bearings out in tub,kenmoreHE3 elite help
Hi shelly 5002 ,kenmore washer front loader eliteHE3,my husband says are bearing in the tub is bad.and he wants to know is there an inner and outer bearing,on tub,and how hard will thias be to fix,my washer is only 5 years old,im very upset over the quaility of this machine,oh well but if u could give me any help what so ever i would app. it thank you
    Scholar:
  • 79 Answers
See http://www.elitebearing.com fro a bearing and seal kit.
Posted on Nov 20, 2009
Replace tub bearing on top loader Kenmore elite
I have a Kenmore elite oasis top loader. The tub bearing caused the noise level to get increasingly higher over a period of a few weeks. Finally it sounded like an airplane taking off. I thought about trying to fix it myself. Meanwhile I talked to the Sears representative and they offered me a one year warranty ( my old warranty ran out last year and I did not renew). The cost was about $135.00. However, I talked to a relative who works in the factory and he thought that was a good deal. I called the repairman and am glad I did. The bearing was stuck so badly that he had to remove outer tub and finally replace with a new one. Two men came the next day and installed the new tub and associated bearing. I saved a lot of money and the washer sings quietly now. So, before you get in over your head, you might want to see if there is an available warranty. Otherwise, get ready for a fight getting the bearing out from under the washer.
Sep 26, 2014 | Kenmore 24032\24036 Top Load Washer
Tip
Replacing a Rear Tub Bearing
Rear Tub Bearing Replacement
(Part 1 of 3)
This advice is for replacing the rear wash tub shell of most Kenmore Elite HE model FRONT LOADERS, along with Whirlpool Duet, and some Frigidaire FRONT LOADER models. This is a repair that would be rated as difficult due to the extensive disassembly and reassembly of components.
The requirement to replace the rear wash tub shell is usually attributed to the rear tub bearing failure in which the bearings are molded into the tub and cannot be replaced otherwise. In some situations the replacement of the inner spinner basket (stainless steel tub) may also be required due to the corrosion and breakage of the spider arms in the back of the basket that support the basket.
SYMPTOMS: Washer exhibits excessively loud “rumbling” type noise during the spin cycle, excessively vibrates, or won’t spin at all.
DETERMINING IF THE BEARING AND SPIN BASKET ARE BAD: With the washer door open, place your hand inside the basket and push straight up. If there is excessive play in the tub (wobbles up and down) the bearing is probably bad. If the spinner basket scrapes against the outer tub shell when you give it a spin, you will have to replace the inner spin basket as well. Unfortunately, you cannot see the condition of spinner basket supports until it is removed from the outer tub shells. In some cases, a brownish colored stain my show up on clothing as the bearing seal has been breached and leaks into the spinner basket.
Before starting this repair, make sure you read through all instructions thoroughly and place the washer is in an area that gives you plenty of space to work.
(cont’d)
on Jul 07, 2008 | Kenmore Elite 45986 Front Load Washer
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
Sep 12, 2014 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bad bearings or the inner tub mount called a spider. Buy a new washer. sorry :(
Nov 15, 2013 | Kenmore Elite 45986 Front Load Washer
I have a kenmore frontloading washer, during the spin cycle a noise like grinding can be heard, grinding can also be heard when turning drum by hand...help
its the drum bearings that support the inner drum,you need to replace these bearings,the problem with this is it was manufactured by frigidaire for kenmore and you cant just buy the inner bearing and lip seal as it comes with the outer rear half of the outer.tub where as with maytag neptune or whirlpool duet you can drive these bearin gs out and re-use the tub half,but you can't buy just the bearings and seal for a frigidaire front loader
Aug 31, 2012 | Kenmore Washing Machines
The washer makes a harsh thumping when washing but spins with no problems
This problem is usually caused by unbalanced loads or damaged balancing springs. This solution might help you out;Rearrange the clothes inside and turn it back on.
If the problem persists , Its means it's the inner tub bearing that is causing the problem,it is going bad and will continue to do so.
The solution is to replace the whole inner tub in order to get a new bearing or you could press it out and find the part number to replace it with.
Thanks and take care
Jun 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Grease on clothes in kenmore front load washer
You have a bad rear bearing. Its a very expensive repair most units you have to buy the back half of the tub to get the bearing. Low end for the repair would be around $400. Sorry to break the bad news hope this helps. _MJ_
Mar 11, 2010 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Robert Rankin
