Question about Pride New Mobility Legend 4 Wheel Scooter
Batteries fully charged on pride legend fuses, isolater checked. checked all wiring appears good connection but system dead, please advise joe
  • Pride Master
  • 1,271 Answers
Hi ,you need to check whether there are any fuses under the seat,
Does the horn work ? , do the power tiller ? the display showing how much the battery is charged
Regards
GeWiz
Posted on Aug 12, 2009
Pride Legend 3 wheel. Has new batteries. They are connected to onboard charger. All fuses are good. Problem:. Scooter will not charge. Please help.
Have you made sure the connectors to the batteries a fully clicked in? I had similar problem with mine, the casing had caught on one & moved one battery terminal clamp, this was after me going over a pot hole. Hope this helps
Dec 27, 2017 | Pride Health & Beauty
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
May 21, 2014 | Pride New Mobility Legend 4 Wheel Scooter
Pride Victory 10 3 wheel , batteries fully charged power in and out of circuit breaker no power at controls nothing works all fuses are good no power there ?
If you have no power at the console but your batteries are good, check the connections of front to rear harness between the front/rear frame. If that connection is good, there may be a serious issue going on. For an authorized service technician in your area; please contact Pride Mobility.
Apr 30, 2014 | Health & Beauty
Batteries won't fully charge
mcdevito75 here, Sounds like the chargeing system has gone bad. Contact Pride online or phone.
Jun 27, 2010 | Pride Line Rally Scooter 3 Wheel Viper
I have a legend pride four wheel electric scooter. It does not run anymore. We checked the batteries and they are good and we charged them. We also went through all of the wiring and made sure the...
Hi. Is the machine display any fault codes, ( flashing battery light)? Is the free-wheel lever in the correct place, Move it in and back again and try it. It is possible that you have a stuck brush in the motor. Get a multi meter and check the resistance through the motor. Check that the brake unit is releasing properly.
If one of the battery lights is flashing, count the flashes and let us know what the pattern is, and we can tell you what it means. Good luck. Neil.
May 09, 2010 | Pride Mobility Products Pride Legend XL -...
I have a 2002four wheel Legend Mobility scooter.
Hi. A lot of scooters have a seperate switch to select a high or low speed setting.
This switch is sometimes labeled indoor/ outdoor.
I have had a few scooters with a similar fault, and the wires that connect to the high/low switch have broken of the terminals on the rear of the switch.
It could also be a faulty speed control pot.
Check these and good luck. Neil.
Mar 08, 2010 | Pride Mobility Products Legend 4-Wheel...
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Pride Legend scooter won't hold charge
check the wiring from the batteries as a wire could have come loose.
Regards
GeWiz
Sep 23, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Machine shut down, everything works except motor all fuses and reset good batteries fully charged cannot find any reason.
Did you check inside the steering stem and see if the conecter plug to the ignition switch is lose or apart?
Aug 24, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Pride New Mobility Legend 4 Wheel Scooter Logo
398 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
