Question about Boston Acoustics MicroMedia Computer Speakers
No sound out of left speaker
I have checked all settings and balances and nothing helps.
To fix this I took mine apart. But I suspect it was the red and white speaker outputs. I unscrewed the screws and moved the red and white speaker outputs around and then put the thing back together. It now works again.
Posted on Feb 16, 2010
2 Suggested Answers
SOURCE: Hp speaker problem. Please help
I have no sound at all, HP Pentium 4...please help
Posted on May 28, 2008
Sound coming through right headphone, but not through left. Sound also not coming through left speaker. Help?
are you adjusting sound through the windows controller or the application you're playing music through? there are a few things that could affect that, there's also the actual sound setup where you can change your setup i.e. surround sound, single speaker, headphones etc
Oct 02, 2013 | Toshiba Satellite Computers & Internet
My Lexus 2004 RX330 only has sound from the passenger speakers. Balance to left produces no sound. Balance to right produces sound on passenger side only.
Just check the wire..it is clear a wiring issue ..It is either from the plugs or the wire itself has a break on ..To be sure just attach a speaker to the left out and see if it has signal ..than re-wire it just to be sure..If you insert another control speaker or anything ..just to see if it has signal ..and nothing gets on the left ..check the settings ..and reset the player ..If this will not make a stereo out ..than the left channel has an issue and need to be checked..Some has separated amplifiers patch and can go bad in just a channel ..but ..usually it is just the wire.. (If you have an amplifier connected ..check it too for settings ..and see if the balance is not all to the right ..)
Aug 09, 2011 | Car Audio & Video
I have the Boston Acoustics BA745 Computer Speaker System. I cannot get the Sub-Wolfer to work. Everything is plugged in but when I turn the volume up on the left speaker module, nothing happens. Is there...
This could be because the speakers arn't getting a stereo signal, but first, double double TRIPLE check the wires are connected correctly. Iknow it sounds patronising but I don,t know if you are 8 or 80 years old and it's often best to go for the most obvious solution. afer making sure all connections are correct, have a look at the cable to the subwoofer - is there any damage to the cable or does the cable look like it may have been pulled - out from the sub or it's connection at the other end of the cable? Having eliminated the possibility of cable damage (it may be worth cheacking the cable to the pc) check various settings on your pc - are you getting sound from your other two speakers? if you are only getting sound from one of the left/right speakers and you're sure there's no physical failure with the speakers, then it's time to check your software. go to the little speaker ikon at the bottom right corner and right click. Select "Playback devices" select "speakers" and click "test" did you hear sound coming from the left speaker then the right? if yes then you definately have a problem with the sub. if no, click "properties" then "levels" and check the balance is set to the middle. If it is, then you should, again, suspect the speakers. Finally check the balance on your media player, if you use windows media player, go to "options" click "enhancements" then look for the balance control and make sure it's in the middle.
Finally, I would like to point-out that this particular speaker system is not known for having a loud subwoofer, put your ear against the hole in it and double check for anything happning inside (a crackling noise would indicate a danaged voice-coil.
Hope this helps.
Jan 08, 2011 | Boston Acoustics BA745 Computer Speakers
My left side speaker is not working. I plugged in another speaker to the sub output (the plug not working) and got nothing, which proved to me that the speaker wire and speaker itself is not faulty. ...
could be the sound card or its driver. Check your sound properties and make sure the correct set up is selected like 2.1, 5.1 adn 7.1. Verify that the volume levels are balanced, and if nothing helps, reinstall the video driver first. If this does not resolve it, might be a good idea to test the speakers on another system just to confirm they are all ok. If that works, you may need to get a new sound card, or test the card on another computer if possible to confirm if it is at fault. Hope this would be helpful to you.
Oct 14, 2010 | Dell 5650 Computer Speakers
I've tried three different sets of speakers and each time the left speaker will not work. I've also tried plugging in my headphones and my left headphone wont work. I've checked all the volume controls and...
Well the jack you plug in has three surfaces. So when you pulled it part way out then the left speaker part of the plug came in contact with the right speaker contact inside the jack and it worked. Speakers are good so if you have checked your volume control in Windows and checked that the balance control is centered it could be that your sound card is defective. You didn't tell me what kind of computer you have and if the sound card is built into the motherboard or if it is an add on card. I don't know if you only have the Window's sound control in Control Panel or if your card has a seperate software for configuring your card but I think the only thing that might disable the left speaker has to be the balance control in Window's sound control or the seperate software.
Nov 15, 2009 | JBL CREATURE II Computer Speakers
My l/r channel will not work
With the radio on u will need to push audio button it will change to something different on the face push until speaker balance comes up & then push butons below it left or right to balance each side of speakers. For me it was the left speakers that i needed to balance good luck John
Jun 06, 2008 | Pioneer DEH-1600 CD Player
Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
JBL CREATURE II Computer Sattelite Speakers Sound Problem
check on the speaker software were you can set master volumeetc. check for balance volume .
Oct 27, 2007 | JBL CREATURE II Computer Speakers
Both right speakers not working
Try to interchange the connections of left channel and the right channel. If there is sound now in the right channel and no sound in the left channel it means that you have problem in the sound card. Otherwise if the problem remains the same you have a defective speaker on your right speaker system but don't forget to take a second look on your speaker wiring.
Oct 22, 2006 | Dell 5650 Computer Speakers
Boston Acoustics MicroMedia Computer Speakers Logo
95 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
