Question about AEG 18 in. Favorit F54850 Slim-Line Free-Standing Dishwasher
AEG Dishwasher 54850 not heating up the water is no getting hot
  • 192 Answers
This could be the electrical element (some use the old traditional element and some (later models) use inductive heater coupled in line with the hose feeding the top sprayer arm. A test with an Ohm meter should indicate if the element is open circuit.
Posted on Jan 19, 2010
The AEG dishwasher not heat the water.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Jun 17, 2011 | AEG 23 in. Favorit 44070IW Built-in...
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
heatman101
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
My dishwasher aeg favorit 50870 not use hot water(not do hot water)
If the water isn't getting hot, then either the water inlet valve that opens the hot water is faulty or the heating element that heats the machine may be bad.
Sep 29, 2010 | AEG Dishwashers
AEH Favorit 50730 dishwasher seems to work fine other than the water never gets hot. Is it easy to replace the heating element or whatever that could be faulty?
If this dishwasher is a residential dishwasher the water that is supplied to the unit is from the hot water side of the sink supply. The dishwasher does not heat the water it uses water from the water heater that is connected to the house. It sounds as if the dishwasher is hooked up to the cold water supply instead of the hot water supply. The heating element you see in the dishwasher is for drying purposes and not for heating water. I would check the hot water supply for your dishwasher to see if that could be the problem. Also remember unless you have a recirculating pump on the hot water there will be an amount of water in the pipe from the water heater and the dishwasher that has sat and cooled down over a period of time therefore when you turn on the dishwasher you will not get hot water immediately due to the distance the dishwasher is from the water heater. You will notice when you turn on the hot water to thew sink you do not get hot water right away you let it run for a minute before it gets hot since the dishwasher is connected to the same valve as your hot water to the sink it acts the same way.
Good luck on your repairs hope this helped.
Dave
Sep 02, 2009 | AEG 24 in. Favorit 50730W Free-standing...
Water not heating. Element replaced with new but still no joy.
The water is heated via a "inductive heater" and not the usual heating elements. This heating device is at the bottom back of the dishwasher and is a cyliderical +/- 15 cm long metal tube. It can easly be removed by the wire clamps at each end. It does have electrical push on connector that just plugs out. If the electrical connections are good I suggest you replace it with a new one (if you can get one).
Mar 23, 2009 | AEG 24 in. Favorit 40660i Built-in...
AEG DISHWASHER, DOES NOT HEAT WATER.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Sep 25, 2008 | AEG 18 in. Favorit F54850 Slim-Line...
Dishwasher
This "Inductive heating element"is in line with the pipe feeding the top spray arm. it is about 15cm long and has a clamp at each end with one electrical push on connecter. It can be reached by taking off the back bottom plate and just follow the spayarm down to this device.
Jun 05, 2008 | AEG 24 in. Favorit 40660i Built-in...
Open Questions:
Hi, I have read all posts for fixing AEG Dishwasher not heating water problem. Most answers were about PCB heater relay. I have a Favorit 80860iW sensorlogic turbo, (turbo is car?) [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800026-1.jpg[/IMG] and i treat it as a lady. Always best materials in, and dishes cleaned before input. Now, I removed door panel, also 2 PCBs inside, but couldn't find any relay to re-solder it. I am posting some photos here, if anyone please see any problem in my PCBs, or the famous relay, just send me an answer where to solder. 1. when removed fascia. [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800038.jpg[/IMG] 2. back side of fascia [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800047.jpg[/IMG] 3. PCBs removed [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800039.jpg[/IMG] 4. PCB with red display panel [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800043.jpg[/IMG][IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800040.jpg[/IMG] 5. PCB with power button [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800042.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800041.jpg[/IMG] 6. PCB on the bottom of dishwasher [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800051.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800055.jpg[/IMG] I am disappointed, its a 2000 expensive buy, told me it would last, and i fixed it 5 times already. The dishwasher program is working normal, it just won't heat no more. I replaced today the bottom sensor, which fixed this problem 2 times in the past, but now, no luck with new part, it don't heat. 7. sensor replaced [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800049.jpg[/IMG] 8. where sensor goes in [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800052.jpg[/IMG] thanks for your time.
Feb 05, 2011 | AEG 18 in. Favorit F54850 Slim-Line...
AEG 18 in. Favorit F54850 Slim-Line Free-Standing Dishwasher Logo
442 people viewed this question
Top AEG Dishwashers Experts
paul
paul
Kolbrun...
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
