Not 350b-old drill press
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
SOURCE: Hi I'm looking for a part for a drill press
check out this url:
www.jalopyjournal.com/forum/showthread.php?t=237685
SOURCE: Need a take up spring for old craftsman drill
Hello. Craftsman only stocks parts for their tools for a ten year period. If you want to look and see just go to searsparts.com.
Your best bet may be to take your worn spring to a hardware store and match it up with one that they have in stock.
SOURCE: Drill Presses - Need manuals for Rockwell 15-350. I found exploded parts diagrams. But not manuals.
Excluding industrial units, drill presses are very similar to each other and most of the low and medium price units are generic tools of far eastern origin so any simple set of instructions for any drill press will apply to most machines.
Mostly the drill press is an intuitive tool to use for anyone who has the slightest engineering experience so most manuals seem to be almost filled with safety information rather than any useful information. The useful stuff should be gleaned from more comprehensive manuals about engineering and workshop practice.
Toolkraft Parts
P.O. Box 80777
Springfield, MA 01138-0777
Tel: 413-737-7331
[email protected]
Good Luck
Lacala69
