Question about Philips GOGEAR SA6045 MP3 Player
It says to connect it to the pc and use device
It says to connect it ti the pc and use device manager to repair.... i did but wat do i do next
  • 101 Answers
Click the repair tab, then click repair. After it has finished repairing your device should be ready to use again
Posted on Aug 02, 2009
Hi icant install ac97 audio driver it show some that software failed system logo and not installed incase some times with lot of tryings if it got installed means then sound comes only in computer speaker...
Go into control panel, system, hardware, device manager (if using XP, other versions of windows also have device manager) you should see a yellow question mark next to the device in question,
right click, update driver, run through the wizard selecting the location where you saved the drivers.
Mar 05, 2011 | Fujitsu Siemens SCENIC P300 PC Desktop
I just upgraded my ti89 and now it will not detect in windows 7
I'm going to take it that your Ti 89 upgrade is a Ti 89 OS update. Check and make sure your Ti 89 OS is up to date with with OS 2.09v. For ti 89 Titanium your OS should be 3.10v. To check the version of your OS from the home screen press, [F1] [A]-About. The OS version should show up at the second line from the top of the "About" window that pops up. If you don't have the updated OS version you should go to the Ti web site and download it. Now let's try getting the computer and calculator connected.
When you have your computer and, Ti 89 calculator connected the calculator should be on and, at the home screen.
Procedure 1.
Go to your Start Menu and search for Device Manager.
Open up Device Manager.
Scroll to the USB controller and click the +. Turn the calculator ON then connect the USB cable to your PC. A new device will appear on the USB controller.
Right-click on the new device and, choose Update Driver Software. The Hardware Update Wizard will appear.
Choose "Browse my computer for driver software".
In the search field type in C:\Program Files\TI Education\Driver Files. Look for the tiehdusb.inf driver file.
Click on Next to finish installing the driver properly
Once the driver is installed click Finish.
Procedure 2.
Now click on the "Ti Connect" software on your desktop. Double-click the Ti Device Explorer located to the left inside the Ti connect window.
The software should start looking for your calculator. A pop-up should display looking something like what is pictured below. Under device your calculator should display. If your calculator is located the software will highlight on to it. Click, "Select" and another window should pop-up.
The next pop-up should look something like this. If your Ti 89 is present it will show up next to device and, probably won't say Titanium. Your cable type and port should be listed too.
If all the information is correct in the window that appears click "OK" and, you should be able to start downloading. You can skip the rest of the procedures. If your Ti 89 still won't connect to the computer goto Procedure 3 unless you have already tried Procedure 3, then goto procedure 4.
Procedure 3.
If the above procedure still does not help then try un-installing and, re-installing the Ti Connect software. After un-installing re-boot your computer. After re-booting your computer you can get the latest copy of Ti Connect software by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti Connect software" At this Ti site under "View: Connectivity Software", Click, "the OS link that applies to your computers operating system". Next, click the Download Item, "Ti Connect software for ....OS". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti Connect software for ....OS will be download to you. Click, "Save" and then a folder will pop up. It is probably a folder that you download too. If so, you may want to change it and, 'Save as" to this folder, "Desktop."
Next right-click the Ti Connect executable on your desktop and select, "Properties." Then click the "Compatibility" tab located at the top of the "Properties" window. Click the box next to "Run this program in compatibility mode for." and select "Windows XP Service Pack 2" from the drop-down menu. Click "Apply" and choose "OK." Double-click the TI Connect executable and select "Next" to begin the installation. Click "Yes" to OK the installation process to proceed. Then click "Finish" to complete the installation. Next, reboot your computer.
Now go back and try Procedure 1 and 2 again. If you have already tried Procedure 1 and 2 twice, go to Procedure 4.
Procedure 4.
If the above procedures fail then try a different cable and if possible a different computer.
If trying different cables/computers fails, please contact and fill out a Ti Cares Customer Assistance Form. You can get there by clicking this link, " Ti Cares Customer Assistance Form "
Attach a system information file to the email reply you receive from "Ti Cares Customer Assistance Form."
To get the system information file:
Go to Start Menu and search for System Info
Once loaded, click on File and choose Save
Name the file FirstNameLastName.nfo
Please check to make sure that system info file(.nfo) is the selected type of file.
Attach the .nfo file to the email reply
Jan 03, 2011 | Texas Instruments TI-89 Calculator
I don't have the disk and i can not find the TI Educational Handheld Device driver anywhere for download also my calc freezes when connected. the pc also has the usb not reconized pop-up every 5 seconds as...
Here is the link to the connectivity software for your calculator. Select the Computer Operating system and download to your computer.
To install the calculator drivers (depending on the cable used) read the following.
Install the drivers first then connect the calculator to the computer with one of the two cables (SilverLink USB, or miniA to standard USB)
The procedure is described in the following, Please read it till the end then try it. If you have any problem, post a comment to this thread.
If you have a USB SilverLink cable, use it to connect the calculator though the I/O (round) port.
If you do not have a USB SilverLink cable, you can use the mini USB to USB Direct cable but you will have to install the correct driver for it.
I do not know what computer operating system you are running and I use Windows XP so I will describe the installation procedure for Window XP SP3.
Install TI connect 1.6 for Windows; if your system is Vista you must install a patch available on the TI website, at the same page where you find TI Connect.
After you install TI Connect, connect your calculator to the computer with the mini USB standard USB Direct cable. Windows will detect the calculator and will try to install the drivers. You will have something that is similar to what is on the three screen captures I am inserting in the post. On the last screen, choose the TI Educational Handheld device and click next.
When Windows asks to stop installation, click continue anyway
After the installation, click finish.
Device manager will show you something like what is on next screen (TI Educational Handheld device)
Run TI Connect to verify that the calculator is recognized. Connect your computer to the Internet and click the Updates Button on the TI Connect tool bar.
Verify that the I/O port (the round one) does not contain any foreign material. Also, for transferring files batteries must be in excellent condition.
Dec 17, 2010 | Texas Instruments TI-84 Plus Calculator
I cannot connect my GR
Even if you cannot connect it to the computer you can still transfer applications from a working calculator.
Here is a copy of a post I wrote to answer that question.
I do not know what computer operating system you are running and I use Windows XP so I will describe the installation procedure for Windows XP SP3.
After you install TI Connect, connect you calculator to the computer with the mini USB standard USB Direct cable. Windows will detect the calculator and will try to install the drivers. You will have something that is similar to what is on the three screen captures I am inserting in the post. On the last screen, choose the TI Educational Handheld device and click next.
Jun 22, 2010 | Texas Instruments TI-84 Plus Calculator
TI connect not working
Here is a copy of a post I wrote to answer your question.
Apr 15, 2010 | Texas Instruments TI-84 Plus Silver...
My computer won't find my ti-84
Mar 22, 2010 | Texas Instruments TI-84 Plus Calculator
Well my probleme is when i plug the usb in my ti 84 plus and after when it downloading after like 5 min it say i have to insert a disk something like that and i dont have the "disk" so please help me
Feb 20, 2010 | Texas Instruments TI-84 Plus Calculator
My usb ports stop working my mouse shows there is power but it is not working wat can i do to fix it i have a dell precision m70. i dont know anything about computers show me step by steb wat to do
check in device manager next to usb see if theres any yellow question marks next to anything related to usb.expand it down to see all
start-[type in search box] device manager] click on it when it appears.Device manager will open.expand by clicking on the+ next to devices.
Jan 03, 2010 | Dell Precision Workstation 670 PC Desktop
Pc working good, but no sound
If you're using Windows, go to device manager [right-click My Computer, click Manage, and click Device manager in the Computer Management Console Window], next access your Sound device and make sure it does not have any yellow exclamation [conflicting drivers] or question [missing drivers] marks. If it doesnt and you still dont have sound, you'll need to download and install audio codecs from your Computer, or sound device manufacturers website...good luck
Jul 12, 2009 | Dell OptiPlex GX260 PC Desktop
Format player
Use the Philips Device Manager to run a Repair on your device - it will give you instructions, and enable you ti fix your player.
-Tha Mp3 Doctor
Jan 25, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GOGEAR SA6045 MP3 Player Logo
110 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
