I wouldn't stop taking medications. It might lead to health issues. Just go on following your doctor's recommendations and I'm sure you will see the result soon.
If you have been having problems with your browser hanging due to a script seen a similar screen to this and pulling you hair out then try this fix before you safe in safemode and diagnose each potential add-on that might be causing the unresponsive script.
I also recommend using either Sysinternals Process Explorer or Windows Task Manager to see if there is another process hogging the CPU during this time, this might be all that the problem is an not with Firefox at all type about:config in the browser then try these values the default value is 20 seconds I recommend a minute for both the chrome and normal script_run_times, if it is set to 0 this means it will wait forever, try to avoid this setting.
Simply right click and modify it will say user set when changed to 1 minute (60secs) i this case.
Since the institution of ObamaCare processing time by Express scripts has increased by about 40%. Ask your physician to write you a two week supply to fill locally. You will have to pay for this but can submit a claim for excess delay in processing. If you don't mind waiting on the phone for a long time you can call Express scripts and request expedited processing. Depending on your condition the delay in getting your medication can be serious so consult your doctor regarding this option.
Does it run out of memory? Could you test printing a very small file? Are you sending an Adobe file to a non post script printer? How large is the file? How do you know it processes?
this is normally java running something, if it tells you its a different program close the program if not press Ctrl + alt + delete change to processes and pick java (it may have more in the name) right click and end process this should refresh java and stop it running excess scripts
Common script errors messages can be eliminated by Clicking:
1. Open Internet Explorer.
2. On the Tools menu, click Internet Options.
3. In the Internet Options dialog box, click Advanced.
4. Click to select the Disable script debugging check box.
5. Click to clear the Display a notification about every script error check box.
6. Click OK.
There are situations when a Web page contains script that takes an unusually long time to run.
There will be a warning message after a certain number of statements has been processed.
The solution is to increase the default number of statements,before the warning is given
1.Go to Start/Run/type :regedit
Open this key: HKEY_CURRENT_USER\Software\Microsoft\InternetExplorer\Styles
(If the Styles key is not present, create a new key that is called Styles.)
2.Right click anywhere in the right pane and create a new DWORD value called "MaxScriptStatements"
(copy and paste that in to the name box) and set the value to the desired number of script statements.
Try 8,000,000 to start with.
Be careful editing the registry.Back up the key first.
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @ www.thebestpcdoctor.com or via 877-407-9229
Java is your first problem get rid of that malware... second problem is you don't have a mac, haha, just kidding, but seriously get one.
To answer your question, I would try uninstalling your add ons 1 or 2 at a time to see which one will fix er back up. If that does not work, get Revo uninstaller from download.com and use it remove firefox (and java) completely. You can download the newest version any time for free. Personally I dont like a lot of background processes so I use the portable version of firefox which is also free.
This is what you should do; Restore your computer to a point before you installed the Defender Pro. Restore the computer to a point where the computer worked well (probably a date when your messenger was working well).
Once you complete the restore process, you can now reinstall a new yahoo messenger an this would work for you.
An easy way to transfer objects (tables, user defined functions, stored procedures, etc.) is to use Enterprise Manager's "Generate SQL" feature. Use this process at your own risk. Doing it wrong could mess up your existing database.
1. In Enterprise Manager, right-click on the old database and choose "All Tasks" then "Generate SQL Script". 2. In the dialog that comes up, click "Show All" then select the checkboxes for "all stored procedures" and "all user defined functions". (You might also want to check some other boxes, depending on your exact situation.) 3. Click the "generate" button and save the script that it creates. 4. Run the script in the NEW database.
If you run the script in your OLD database, it may destroy your objects, and that would be very bad. Make sure you run the script in your NEW database. (While we're on this subject, it's a good time to mention that you should back up your database before you start this process, and you should make changes to a test system before migrating it to production.)
That should move your stored procedures and user defined functions over.
You can use a similar process to move tables, views, users, and other objects over as well.
