The screen is all blue with ANT3 in the upper right corner and no sound.
The set shuts off afer about 5 minutes.
Any solution?
Press the AV button on the remote, it will alter the interface with your receicevr. It will automatically pick your receiver if it is sending signal properly. If this doesnt work try another tv on your signal box to see if you get the same problem. Bet its the AV button though. Best of luck dave.
Thanks Dave. Tried that , no go. I hooked up another TV and it works fine. I did notice that the blue Light is the only one on. The red and green remain dark.
Sorry I was not clear. The rear projection still has the same symptoms.ANOTHER TV worked fine when connected to the cable. The lights I spoke of may be more correctly called the dlp bulbs. Only the blue one turns on.The other two remain dark until it turns itself off.
