External counter has been enable, u need to disable it...
Each signal will be enabled by configuring the setting code "08-9016" (Counter installed externally).
08-9016
0: No external counter (Default)
1: Coin controller
2: Card controller (For Japan only)
3: Key copy counter
5: Coin controller supporting mixed-size
SOURCE: ''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
SOURCE: after switch on the toshiba e-studio coming uo
please do the following..
SOURCE: Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
SOURCE: papaer jam in toshiba e-studio 181
try changing the paper u use..... i recommend typex or xerox...
