Question about Hitachi 53SBX59B 53" Rear Projection Television
How do you replace the lamp in a 53sbx59b? - Hitachi 53SBX59B 53" Rear Projection Television
  • 4,889 Answers
Replacing the projection tv lamp is a pretty simple procedure provided you can locate it.:) It is as simple as pop the old one out and the new one in. However you should make sure that the tv is turned off for a while before you touch the lamp or "it may be hot enough to burn your skin". Secondly do not touch the lamp receptacle. I have seen people break the receptacle while removing the lamp. Last but not least if you are not able to remove the lamp dont pull hard, look for some kind tab or lock that is holding the lamp in place. You will need to press the tab to release the lamp. While sliding the lamp in you should hear a "click" sound which means that the lamp is "locked" in position.
Also do not touch anything else. The tv set can hold tremendous amount of voltages(upto 15000V in some sets). Therefore you should proceed with extreme caution. If you doubt that you cannot do it yourself please dont do it and take the assistance of a qualified technician.As my mentor always says "Your life and limb is worth much more than this" .
Feel free to postback if you need more help.
Sai.
Posted on Aug 02, 2009
I have a 53" Hitachi Rear Projection TV, Everything works except the color. The 3 color projection lamps are functioning and all of the tv's focusing features appear to be functioning as well. It has a...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 14, 2010 | Hitachi 53SBX59B 53" Rear Projection...
Red and green outkines figuires and blue lamp is out
Convergence is dead,must know how to solders.Buy a convergence kit,replaced what in that kit.Tries Tv repair World.com,Tvrepairkits.com.
Jan 12, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 27, 2009 | Hitachi 53SBX59B 53" Rear Projection...
My mirror is broke in my big screen do you have to buy a special mirror or can you use any mirror?
The mirrors are specific to the unit as they have slight curves to bend the picture correctly so it aligns to the screen properly. To ensure you get the correct picture for your unit, you would have to order the manufactures original replacement part. You can order an new OEM replacement mirror for this model (53SBX59B) from a major Hitachi parts distributor at the link below:
Hitachi 53SBX59B Replacement Part Mirror / 53" Inner Mirror
Apr 13, 2009 | Hitachi 53SBX59B 53" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Need part number????
The Hitachi part number is: 2338313 and is available for $3.22 from tritronicsinc.com
Hope this helps,
Dan
Aug 26, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Spilled Water... where can I order new circuit boards?
Your Talking real expensive to replace the chassis in a projection. Was the Tv on when the water spilled? If it was only plugged in on standby it may be an easy fix. Do you have any soldering skills or troubleshooting experience?
Jan 13, 2008 | Hitachi 53SBX59B 53" Rear Projection...
53sbx59b Hitachi 53 inch proj tv
Call the 800 number with the new remote. Sometimes they will have additional codes. Or with the instructions with the new remote you can manually get it to work. You must follow instructions carefully. Look for this section in the instruction booklet
Dec 29, 2007 | Hitachi 53SBX59B 53" Rear Projection...
Hitachi 53SBX59B 53" Rear Projection Television Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
